Flowmaster Force II single 3" exhaust
Old May 24, 2006 | 03:16 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Flowmaster Force II single 3" exhaust.Single 3" driver side hidden tailpipe.Fully welded as one piece,no clamps.It has a Summit 3" cutout welded in where cat would be.2-3 years old in excellent shape.Painted with Hi Temp silver exhaust paint.Only removed as I am going to dual exhaust.Must be picked up,or we can meet to deliver,other possibilities?
$100
Email or PM me if interested.
john.winship@cmjackson.com or onebad82z@excite.com
Old May 25, 2006 | 08:08 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
open to offers..
Old May 25, 2006 | 06:23 PM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
Axle/Gears: 9 bolt 3.91
Wher in NY are you i'm in Chester, I was just going to buy the same exhaust, but I would buy used. Would I be able to reuse the cutout,it would help. Also since the exhaust is welded would I have to drop the rear down to install it? If so I might still buy it.
Old May 26, 2006 | 08:05 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
The exhaust is in Warwick,NY.The cutout can be reused,I welded a three hole header flange on the y pipe end of it,so all you would have to do is weld a matching header flange on the end of your y pipe and bolt it up.Right now it is cut right before it goes over the axle to remove it from the car,which would allow you to put it on without dropping the rear and have just that part welded up.
Old May 26, 2006 | 09:28 AM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
Well, if I had a welder i'd be over to pick it up. But I can't see spending money for someone to install my exhaust. thanks anyway
If I was still working in this ****ty field, i'd have someone to weld it.
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
ericjon262
Sep 11, 2015 06:07 PM
89fast5oh
Sep 8, 2015 09:55 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
