PARTING OUT THE BEAST 350ci built and t-5 built
Old May 24, 2006 | 08:36 PM
shaddow_wolf's Avatar
Car: 86 z28
Engine: built 350ci
Transmission: built t-5
i will be parting out my car now due to no one wanting to buy it. check the other posting areas for the rest of it.
would like pick up but will check into shipping
TURN KEY 350 MOTOR- $2000
Engine / Rotating Assembly
32,000 MILES STOCK AND 1100 MILES BUILT
91 350 cubic inch roller block motor 43,xxx miles total
• 10/10 ground crankshaft reconditioned / polished
• 10/10 rods sized and polished
• new clevites bearings
• complete felpro gasket set
• new TRW pistons flat top 4 cc relief 9.5to1
Fuel/Air Delivery
• Holley 600 cfm zinc plated electric choke carb
• Holley 10 inch chrome air cleaner assembly
• K&N 10 inch rechargeable air cleaner
• Weiand x-celerator manifold 2000-6500 rpm range
• Bowtie phase II iron heads ported and polished 2.02int 1.60exh valves with bowl blending seat size 1.55 outside diameter
Cam/Valve Train
• GM performance parts zz4 cam Duration @ 0.050" 208/221 Valve Lift 474/510, 112 Lobe Center Separation
• Crane cams hydraulic roller rockers.
• Comp cams magnum pushrods 5/16 stock length
• Comp cams valve stem seals umbrella seals
• Comp cams 3/8 screw in studs
• Proform 1.6 full roller rockers 3/8 blue anodized
• GM performance lt4 light weight springs 1.32 od
• GM performance lt4 light weight retainers
• GM performance light weight valve stem locks
• ARP posi locking adjustable rocker arm nuts
Ignition
• Mallory dual point distributor
• Mallory distributor cap
• Mallory rotor
• Mallory dual point 6000+ rpm floating points
• Accel super coil 12 volt 50,000 output
• Accel ballast resistor
• Accel 8mm double silicone spark plug race wires
Chrome
• Holley aluminum polished finned valve covers
• Holley aluminum chrome air cleaner
• Chrome water outlet housing
• Chrome oil fill cap
• Chrome power steering cap
• Chrome alternator brackets
• Chrome valve cover hold downs
• Chrome t-handle valve screws
• Chrome wire looms
• Chrome distributor hold down
• Chrome dual throttle springs
• Chrome valve cover breather
• Chrome fuel filter Mr. Gasket
BUILT T-5 TRANS- $800
• T-5 Borg Warner world class built with forged internals 5 speed
• Clutch masters stage 1 HD clutch
• Clutch masters HD pressure plate.
Old May 25, 2006 | 02:53 PM
Car: 86 z28
Engine: built 350ci
someone has to want this
Old May 25, 2006 | 04:10 PM
john8169's Avatar
On Probation
I'll consider the 5-speed trans. What parts are in it and how much shipped to florida 34997 ?
Old May 25, 2006 | 06:24 PM
rageracing's Avatar
Car: 89 Camaro
Engine: 408ci sb, 195AFRs, 750 Mighty Demon
Transmission: JW Full Manual Valve Body TH350
Do you know what the trans is rated to? (hp/tq)
Old May 25, 2006 | 07:09 PM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
how low are you willing to go on that engine?
Old May 26, 2006 | 12:25 AM
Car: 86 z28
Engine: built 350ci
2000 is the lowest it was not suppost to say or best offer i have way to much money in that motor to just give it away. i guess if someone wanted the motor and tranny i would give it for 3000.
the trans was built when i bought it off my friend. it is suppose to be able to handle 400 hp and 350 tq
Old May 26, 2006 | 09:47 PM
Aweasel's Avatar
Car: Red '89 IROC-Z
Engine: 350, Patriot 195s,
Transmission: T56, Hurst Shifter, Alum. DS, 3.73
looks like you're getting rid of just about everything there from the engine so my question is....are you parting with the headers?...if so I may be interested.
Old May 27, 2006 | 01:23 PM
Car: 86 z28
Engine: built 350ci
as long as i can get a confirmed buyer for the motor and the trans i can part the car out fully.
as for the headers i think i want to sale the complete exhaust together headers with the dual pipes for like $250
Old May 6, 2008 | 12:56 AM
pandemic_ratio's Avatar
Car: 1992 RS Camaro
Engine: 350 small block V8
Transmission: icky automatic
Re: PARTING OUT THE BEAST 350ci built and t-5 built
how much for the ignition system? it is a points distributor right?
Old May 6, 2008 | 05:29 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Thats cool the signal lights with the bow ties. How did you do that??
Jake_92RS
Jan 28, 2020 10:37 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
