v6 parts!
Car: 1986 Firebird
Engine: 3.4 outa 95' bird
Axle/Gears: 3.42 open rear
v6 parts!
i have 3.4 exhaust manifolds, 3.4 lower intake, 3.4 cam, a 3.4 y pipe that is 5 months old and has been cut/welded with a ball flange on it that exits strait back, it doesnt go to stock location, it will work if you want to do a side pipe or cut it up for a turbo system. i also have a coolant overflow tank, i might have other stuff layin around, ill post later after i take a look in my basement.
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
Might be interested in that 3.4 cam.. how much you want?
Car: 1986 Firebird
stuff is still up for grabs, i also have a set of 3.4 heads with 2 cooked valves and 1 sping missing(had to take one off, my new heads came with 1 broken spring). there are no cracks, they arent warped and havent been shaved at all, so there is plently of material if you plan on shaving them. they are worth a 95.00 core charge at napa
LT1Formula
20
Nov 14, 2015 12:02 AM
