Parting 86 Iroc and 92 RS in Kansas City area
Car: 92 camaro z
Engine: 383
Axle/Gears: 4:11
Parting 1992 RS Camaro interior (grey), drivetrain 305 TBI , trans is fresh with less than 1000 miles, ground effects, front damage.
Parting 1986 Iroc, black interior, TPI 350, rear disc 3:23, TPI car.
Parting 2 1986 Trans Ams, rear disc posi, 305 TPI, GFX, interiors, good 700r4's, and good running long block 305's
Let me know if interested in anything.
Axle/Gears: '01 3.42 10 bolt
i'm interested in the air cleaner assembly from the IROC. i need both the base and the top. how much with shipping to 40229? and how would you want payment?
Car: 92 camaro z
Engine: 383
Axle/Gears: 4:11
Originally Posted by fwdsucks87
does the tpi still work. do u have the tpi still. id love to swtich mine to tpi. id like to have the whole setup computer and all, let me know.
Car: 92 camaro z
Engine: 383
Axle/Gears: 4:11
Car: 86 Z28
Axle/Gears: 327
LOOKING FOR INSTRUMENT CLUSTER, SEATS, AND TURN SIGNAL FROM 86..IS THE HOOD IN GOOD CONDITION? DO YOU HAVE A SPOILER? LET ME KNOW ESPECIALLY ON THE INSTRUMENT CLUSTER AND TURN SIGNAL..OH YEAH WHAT ABOUT THE DASH IS IT IN GOOD CONDITION? ALSO LOOKING FOR RIMS
Car: 92 camaro z
Engine: 383
Axle/Gears: 4:11
Car: 92 camaro z
Engine: 383
Axle/Gears: 4:11
Originally Posted by ace16a
What are you looking to get for the 86 disc rear? what's the condition?
Car: '88 Camaro Sports Coupe
Engine: 305 tbi
Transmission: th-700r4
92 rs
looking for a complete rear axle shaft. shipped to 50322. also, if the passenger side door is in good condition how much for it
Car: 1983 Camaro in gray primer
Engine: Vortec 350
Transmission: T56 6-speed out of 94 trans am
Axle/Gears: 3.27 posi out of 94 trans am
I need a dual electric fan set up. If either car has one, how much shipped to GA 30101? Thanks
Car: 92 camaro z
Engine: 383
Axle/Gears: 4:11
Originally Posted by Tuttlet
Is 67 still for sale ? Do you have any pictures?
eBay Motors: 1967 CAMARO DRAG CAR NOT 68 69 RS SS Z28 1ST GEN (item 8076891855 end time Jun-25-06 19:09:22 PDT)
Car: 91' Z28
Engine: 355-Supercharged
do you have the plastic from the TBI setup that goes where the dual snorkel setup would go on a TPI car, basically the cover ? PM me please.....
Car: 92 camaro z
Engine: 383
Axle/Gears: 4:11
Car: 92 camaro z
Engine: 383
Axle/Gears: 4:11
Originally Posted by bpeters113
what all has been done to the transmission to make it 'fresh'?
Originally Posted by sach712003
I am interested in a complete AC setup for a serpentine setup, how much?
Originally Posted by Gunner823
I need the MAF ASAP if you still have it.
Car: 1991 hot rod black camaro
Engine: 383, full roller
Axle/Gears: 3.27 9-bolt
any modifications done? (shift kit, 3-4 up****, upgraded parts?) and what are you wanting for it? im about an hour and a half south from kc.
Car: 92 camaro z
Engine: 383
Axle/Gears: 4:11
I would need all the lines, evaporator, canister, blower motor, blower assembly including the thing in the blower assembly (dont know what its called). The only things I dont need is the actual compressor and condensor the thing that sits in front of the radiator.
Car: 92 camaro z
Engine: 383
Axle/Gears: 4:11
Engine: 305 tbi
Originally Posted by 92orange
Drum or disc rear, $85 and shipping for passenger door, really good shape. Door is a freight item sure it will be around a $100 for shipping let me know if interested.
Car: 1987 IROC-Z
Engine: 305 LB9
Transmission: 5 Speed
Axle/Gears: 3.70 Posi BW 9 Bolt
DO you have a set of spindles off one of them??? mrraffi@aol.com
Car: 92 camaro z
Engine: 383
Axle/Gears: 4:11
Originally Posted by 95Cam86Roc
do you have an overhead console?
Originally Posted by 53burb
Is the TPI still available???
pm sent on transmission
Car: 92 camaro z
Engine: 383
Axle/Gears: 4:11
Originally Posted by 5.7tpiroc
how much for all the seats on the 86? do you have the foglights for it as well?
Car: 92 camaro z
Engine: 383
Axle/Gears: 4:11
Originally Posted by Sexy89RSGrl
How much for the door gfx? Just the part attached to the door, not the lower rocker gfx.
Car: 69 Suburban
Transmission: 400
tpi
Are you sure the IROC you are parting out is a 350?? I read that the Camaros & Firebirds in '86 were 305s. Is the distributor included in the deal??
Car: 92 camaro z
Engine: 383
Axle/Gears: 4:11
Thanks,
Damien
Originally Posted by yjischoking
clean passenger fender off the 92?
Car: 92 camaro z
Engine: 383
Axle/Gears: 4:11
Originally Posted by wannaz
Do you have a yellow letering shiftr plate .Is it in decent shape?If so how much shipped to 16822
how much for the 16" iroc rims shipped to 42071 and can you post or send pics to bobidontcare105@hotmail.com Thanks
Car: 69 Suburban
Transmission: 400
Would you be able to post pics of the TPI unit or email them to
peganyee1@msn.com, please??.
I would need the following:
1 - TPI - everything from where it bolts to the heads to the plenum
2 - MAF sensor
3 - O2 & Knock sensor
4 - Wire Harness
5 - ECM w/chip
6 - Distributor w/cap & rotor
7 - water neck
8 - throttle cable & bracket
Thanks,
Chris
2 - MAF sensor
4 - Wire Harness
5 - ECM w/chip
7 - water neck
Thanks,
Chris
Car: 92 camaro z
Engine: 383
Axle/Gears: 4:11
Car: 92 camaro z
Engine: 383
Axle/Gears: 4:11
2 - MAF sensor
4 - Wire Harness
5 - ECM w/chip
7 - water neck
Thanks,
Chris
2 - MAF sensor
4 - Wire Harness
5 - ECM w/chip
7 - water neck
Thanks,
Chris
Originally Posted by darth442
Are the rear quarter panel gfx in good shape on the 92 RS?
Car: 69 Suburban
Transmission: 400
Thanks for the pics. When you converted to a 350, did you upgrade to the larger injectors & use a 350 computer & chip?? I assume your $250 price does not include shipping. How much to ship to 85242?? Would everything I mentioned earlier, be a problem to include in the deal?? If everything is included, consider it a deal. PM me how you want to be paid. I have PayPal or I can send you a check from my bank...
Chris
Chris
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
Hey I'm only a few hours away from you, is that L98 available??? How many Miles on it, and does it run?
Car: 92 camaro z
Engine: 383
Axle/Gears: 4:11
Originally Posted by Stevo
How much for all and what is included?
Thank you.
Thank you.
Originally Posted by Desert86Roc
Do you still have the engine wiring harness?
