2 series 3.73's
Car: 1991 Z28
Engine: 357
Transmission: T-56 waiting to go in!
Axle/Gears: 3.73:1
2 series 3.73's
have a set of brand new in box richmond 3.73 gears for a 2 series carrier. looking for $150 obo
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
What exactly do you mean 2 series carrier?9bolt 10 bolt ,what?LSD OR PEG LEG?Not sure if my 10 bolt is a 2 series carrier
Car: 1991 Z28
Engine: 357
Axle/Gears: 3.73:1
sorry theyre for 10 bolt. 2 series meaning if you have a 3.08 or lower gear in your rear end right now, these gears will work without having to have a ring gear spacer. They will work with posi or peg leg rears, doesnt matter.
Your profile says you have a stock 2.73 rear so that would be a 2 series carrier.
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Yeah if the ones in it are stock.Thats what my rpo codes tell me.I havent taken the time to check behind the diff cover but it runs like its got highway gears,well, before with the 305.I haven't gotten it running quite right enough to drive yet with this new combo,but should be really soon.Even if i needed the different ring gear spacer that shouldnt be much more.My only worry is i may use nitrous and i've heard higher gears can be benificial when you use N2O,and i could keep my good gas mileage when not raceing.Do you know?Have to find out and think about it.Thanks
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Still havent had a chance to check it yet.I'm chaseing down a massive vacume leak in my intake so i can actually drive my car.It's at a buddy of mines shop,hopefully i'll be driven it by fri.I'll have to get back with you when i get it home
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
