350 with Trick Flow heads
Car: 1986 Olds Cutlass Supreme
Transmission: 200-4R
Axle/Gears: good question...
I still have this engine sittin here. The bottom end is stock, but was probably rebuilt at some point because it is clean! The bearings all looked good, no old oil in it, or carbon build up. I put a new oil pump and pan gasket on it. Oil pressure never went below 25psi even when at 200* (which is the hottest it ever got)
A set of Trick Flow Kenny Duttweiler #TFS-30400003 heads are still on it. They've been pocket ported and bowl blended. I have the Trick Flow chromemoly 7.25" pushrods. GMPP head bolts and Ultra Seal head gaskets. Less than 1K miles on them!
$1250 for all. $800 for the heads and pushrods. $450 for the bottom end.
Pickup only, except for the heads. Those I can mail at buyers expense
Youngstown, Ohio
Youngstown, Ohio
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
theshackle
Mar 5, 2017 06:37 PM
Mickeyruder
Sep 2, 2015 02:45 PM
NinjaNife
Aug 23, 2015 11:49 AM
Dialed_In
Aug 20, 2015 01:45 PM
