Engines for cheap or trade
Old Jul 19, 2006 | 07:21 PM
facelessnumber's Avatar
Car: 91 RS
Engine: L03 carbed
Transmission: 700R4, rebuilt+kit
Axle/Gears: 3.42, posi, disc
I have a couple of engines to get rid of, both are junkyard pulls and are in unknown condition so I'll let them go cheap. Need to get them out of my way.
One is a 305, I think it's an '84 block. Some light rust. It has what I believe to be '67-'71 327/350 heads. The heads are pretty clean, appear to have been machined at some point. There are no rockers or pushrods, so I would assume the bores haven't been exposed to weather. But I have no idea how long it's been since this engine ran and I don't know what if anything might be wrong with it. I can get you the casting numbers if you're interested.
Also have an Olds 307 which is complete with all the accessories, manifolds, HEI distributor, etc. Everything but the carb.
I can deliver one or both of these within a reasonable distance from central MS.
I would also be interested in trading for Camaro parts too if you have something I might want:
Dash pad
Driver's side right seatbelt trim, gray
Carpet for hatch area, gray
Front bumper cover/front valance for '91-'92
Passenger side headlight frame
Two center caps for '85-'87 IROC wheels
'91-'92 Z28 spoiler
HO air cleaner
145mph cluster for '91-'92
Z28 hood, grille, emblems, etc...
Old Jul 19, 2006 | 11:15 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
would you sell just the distributor?
Old Jul 20, 2006 | 12:24 AM
Car: 91 RS
Engine: L03 carbed
If you mean the distributor from the 305, I don't have it. The 305 is just the heads, block, pan and what's in between. No intake, carb, dist, etc.
If you mean the Olds distributor, yes, I'd sell you that. It's complete, looks to have a relatively new cap, coil, etc. Should be ready to go.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
dutch930
Sep 11, 2015 06:58 AM
Catcher55
Aug 15, 2015 07:08 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
