SLP Y-pipe + free headers(need repair) $190
SLP Y-pipe with 3 bolt flange and 2 O2 bungs, it was fitting well before I removed it. You also get a set of 1 3/4" SLP headers. The passenger header has been clearanced to allow for the #8 plug. The driver side header is not well
The #7 primary tube has separated from the collector. Headers converted to non AIR configuration. Headers are coated. If you're real good with welding and metal work, maybe you can fix this. I can probably dig up the original receipt as well if you have the time to talk to SLP and maybe work something out with them. I have some detailed photos of the damage that I can post if there's interest. $190 + shipping.
thanks
-Mark
The #7 primary tube has separated from the collector. Headers converted to non AIR configuration. Headers are coated. If you're real good with welding and metal work, maybe you can fix this. I can probably dig up the original receipt as well if you have the time to talk to SLP and maybe work something out with them. I have some detailed photos of the damage that I can post if there's interest. $190 + shipping.thanks
-Mark
Magman
Sep 12, 2015 10:43 PM
hectre13
Sep 8, 2015 03:38 PM
