Misc drivetrain parts
Old Aug 8, 2006 | 03:05 AM
Drew's Avatar
I'm cleaning out my storage and everything that I can't use is going away.
1976 3970010 casting 4-bolt main 350, Block, crank, rods, stock pistons, newer double roller timing set, oil pump, pan, timing cover, no cam, no heads, completely disassembled. Ran perfect when it was tore down, was going to refresh it then I came into another block and used it instead. $150 local pickup!
Front crossmembers, V8... Two available, from 86 V8 cars, motor mounts, A-arms, spindles, etc. $FREE local pickup only!
9-bolt parts rear end, no carrier, gears, brakes, or cover. $offer
Transmission crossmember
Stock WS6/Z28/Iroc/1LE springs, $75/set +shipping
Sway bars, larger V8 bars, not 36/23, more likely 34/21, but a huge step up from stock 6cyl bars. $75/pair
700R4 cores, V8, V6, $offer
Brake boosters and Master cylinders, prop valves, disc/drum $offer
10-bolt PBR disc break backing plates, hardlines, and flex lines $offer
PBR Rear disc break calipers, need overhaul! cores! $offer
V6 T5 setup, performance aftermarket racing clutch, low miles. Also have throw out bearing, early (84) 2.8 flywheel recently turned, and good pressure plate. Worked perfect when pulled, motor blew up. $offer
2.8/3.1 Fiero valve covers, cast aluminum, need refinished. Dress up that 2.8 or 3.1! $offer
LG4/L03 TBI Carbed style V8 exhaust manifolds $offer
LG4/LO3 TBI Carbed style Y pipe $offer
LB9/L69/L98 TPI/HO exhaust manifolds, like new $75 +shipping
86 LG4/Auto ECM w/prom $offer
86 LG4/Auto engine harness $offer
86-up LG4 lower electric fan mounting bracket $offer
85-87 TPI intake ducting, from 86 T/A, bellows to airfilter canister $offer
Universal Dry NOS Nitrous system, Sniper bottle (orange) needs to be recertified, solenoids, brackets, instructions, etc. No -4 feedline from bottle to solenoids, and no bottle brackets. Some additional pieces are included. $300+shipping
7730 ECM w/o prom $40 +shipping
90-92 3.1 5spd prom $50 +shipping
Cruise control parts, 86-up TPI/Carb $offer
Mechanical Fuel pump for carbed 2.8, like new! $20 +shipping
Carb for 2.8, non computer controlled, $40 +shipping
S10 manual steering box $offer
Local sales prefered, pics and paypal available, email with needs.
Old Nov 7, 2006 | 03:11 AM
missouraman's Avatar
Car: 1991 trans am
Engine: 5.0l TPI
Transmission: 700 R4 Auto
Axle/Gears: Don't know... DO U!
interested in nos. send pm maybe with pics or more info. Newbie at nos and want to install in 91 t/a 305 tpi
missouraman@gmail.com
Old Nov 7, 2006 | 06:53 AM
redlsone's Avatar
was wondering the condiion of Brake boosters and Master cylinders, prop valves, disc/drum and if you had any pics. would be shipped to 34715
mark
Old Nov 7, 2006 | 12:32 PM
anthony64ss's Avatar
Car: 1984 Z28
Engine: L31
Transmission: WC T5
Axle/Gears: 10 bolt 3.73
wondering if you could e mail me pics of the pbr calipers: punk0203@aol.com thanks
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
3rdgenparts
Aug 5, 2015 11:57 PM
