Converted LT1 to L98 intake and parts
Old Aug 14, 2006 | 05:51 AM
85C4's Avatar
Car: whatever has the most gas in it
Engine: GM v8
Transmission: Uumm that's contingent
Axle/Gears: See prior line
I have a converter LT1 intake that will fit on older SBC. It worked well for me but I will say, the holes that were drilled to mount the manifold to the heads were off, so they were opened up to fit. Its not pretty but if run washers on your mounting bolts you cant tell.
It comes with an almost new BBK 58mm throttle body
fuel rails
custom stainless steel braided fuel lines (Made to work with on stock TPI car)
26lbs LS1 injectors
Holley adjustable fuel pressure regulator
throttle bracket
remote thermostat housing
and a K&N cone air filter.
I will not part out the set up, it comes complete. This is everything you need to replace that stock TPI.
$550 + shipping or it can be picked up from NJ 08872
Price is Firm.
Old Aug 16, 2006 | 04:39 AM
74vette's Avatar
Car: 74 and 87 convert vettes
Engine: 383 /350
Transmission: 400 / 4+3
Axle/Gears: stock
i'm interested, shipping to 97206 ?
Old Aug 16, 2006 | 05:23 AM
85C4's Avatar
Engine: GM v8
I'll do it shipped to our door for $550.
Old Aug 16, 2006 | 02:50 PM
74vette's Avatar
Engine: 383 /350
Axle/Gears: stock
Sold - how do you want the money sent.
email me at kenholmes2@msn.com
Old Aug 16, 2006 | 06:35 PM
85C4's Avatar
Engine: GM v8
paypal, pm sent
1992 Trans Am
May 10, 2023 07:19 PM
1984HO
Mar 19, 2021 11:59 AM
midge54
Dec 27, 2019 04:14 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
