They're IN!! Memcal adapters for all!
Old Oct 4, 2006 | 07:39 PM
  #51
ryan.h's Avatar
The difference is, mine is easier to use, and has a feature so if you hit a bump, your memcal doesn't fall out... and it's cheaper.
The memcal will only go on ONE way with my adapter. Not so with the moates.
The adapter has a hole to take a cable tie or piece of wire to secure the memcal. Moates unit doesn't.
Finally, Moates - $35+shipping, mine - $15 shipped.
Old Oct 4, 2006 | 07:43 PM
  #52
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
Ok I can deal on that hows it installed?
Old Oct 4, 2006 | 09:01 PM
  #53
ryan.h's Avatar
See pics on pg 1. It plugs into the ecm and memcal.
Old Oct 6, 2006 | 09:08 AM
  #54
ryan.h's Avatar
I received parts for 15 more... so they're back in stock.
Old Oct 9, 2006 | 09:34 PM
  #55
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
Do you sell any burning hardware at all? Will this adapter work on both the 1227165 and 122730 ECMs? If I don't get the ZIF socket whats the chances on breaking something with the pry it out method? How much abuse will these take?
Old Oct 9, 2006 | 09:44 PM
  #56
ryan.h's Avatar
Sorry, no burners... ebay has them pretty cheap.
I don't know enough about the 7165 to say yes or no*****. If it uses a memcal like on pg 1, and looks like it will fit, it probably will work. The ZIF socket is just a handy thing to have, it's not necessary by any means.
I burned literally over a thousand chips using a regular socketed one... each time prying it out with a small screwdriver... and replacing it... and taking it out... and replacing it...
I doubt 99% of the people here will ever catch up to me in that respect. If you're planning on it though, like doing something nobody has ever built/done before... buy the ZIF. Then you don't need the screwdriver. (just flip a lever and the chip falls out)
*****edit: Yes, I'm pretty sure it'll work.
Old Oct 9, 2006 | 10:09 PM
  #57
I have found the burner you suggested on Ebay. It seems pretty rudementry. I do believe it listed the chips you sell as a chip it will burn. Have you had any experience with this burner? If so have you ever compared it to the one Moates sells?
Thanx again.
P.S. Here is the list of chips it will burn.
EPROM (Not include Vpp=13.5V devices)
27C16,27C32,27C64,27C128,27C256,27C512,27C010,27C020,27C040,27C1001
M27C1001,M27C2001,M27C4001
27C080,M27C801,M87C257
2716,2732,2764,27128,27256,27512,27010
FLASH Memory
28F64,28F128,28F256,28F512,28F010, 28F020
MX26C1000, MX26C2000, MX28F1000, MX28F2000
Am28F256A, Am28F512A, Am28F010A, Am28F020A
intel:
i28F001BX, 28F004, 28F008, 28F016
SST28SF040A, LE28F4001
29F64, 29F128, 29F256, 29F512,29F010, 29F020, 29F040, 29F080
29F001,29F002, 29F004, 29F008, 29F016, 29F032
AT29C256, AT29C512,AT29C010A, AT29C020, AT29C040,AT29C040A
W29EE512,W29EE011, W29EE012, W29C020(128),W29C040
PH29EE010(W29EE011)
ASD AE29F1008 (AT29C010), AE29F2008 (AT29C020)
AT49F512, AT49F010, AT49F020, AT49F040
SST39SF010, SST3S9F020,SST39SF040
AT49F001,AT49F002, AT49F008A
Am29F512, Am29F010, Am29F020, Am29F040,HY29F080
29F002, 29F002T, Pm29F002T
EEPROM
28C65,28C64, 28C128, 28C256,28C512, 28C010, 28C020, 28C040
M28C16A/17A (DIP28)
28C16,XLS2816 (DIP24)
AT28C64B,AT28C256,AT28C512,AT28C010,AT28C020,AT28C040
EEPROM
W27E512, W27E010, W27C010, W27C020, W27C040
SST27SF256, SST27SF512, SST27SF010, SST27SF020
MX26C4000
Vcc = 3.3-3.6V SST37VF512, SST37VF010, SST37VF020, SST37VF040
Serial (I2C) EEPROM
24C02,24C04,24C08,24C16, 85C72, 85C82, 85C92
24C32,24C64,24C128,24C256,24C512 (C,LC series)
PCF8572 or 8572,PCF8582 or 8582,PCF8592 or8592
Microwire EEPROM
8 bit:93C06, 93C46, 93LC46, 93C56, 93C57,
93C66, 93C76, 93C86,93C13,93C14
16 bit:AT59C11, AT59C22, AT59C13
CAT35C102, CAT35C104, CAT35C108
93C06A ,93C46X,93C56,93C66,93C76,93C86 (NS)
SPI EEPROM
Atmel:AT25010,020, 040 (A8-A0)
AT25080, 160, 320, 640, 128, 256 (A15-A0)
ST:W95010....256, Microchip 25x010 - 25x640
25010,25020,25040
25C080,25C160,25C320,25C640,25C128,25C256,25C512
AT25HP256,AT25HP512
AT25HP1024
CAT64LCxxx (16 bit data I/O)
CAT64LC010, CAT64LC020, CAT64LC040
PIC MCU
16C84, 16F84, 16F84A ,16F627,16F628,16F627A,16F628A,16F648A 16F818,16F819 12C508/A, 12C509/A, 12CE518, 12CE519, 16C505 16C620 16C621, 16C622, 16CE623, 16CE624, 16CE625, 16C710/711 16F630,16F676
Old Oct 9, 2006 | 10:14 PM
  #58
ryan.h's Avatar
I am using the Willems burner... and even though it was made in hong kong (or some far east country), it has worked flawlessly. The trick is learning how to set it up the first time. So expect lots of "Burn Error"s until you figure out how to set the switches.
Overall, highly recommended.
I've never used the moates one.
Old Oct 12, 2006 | 09:57 PM
  #59
ryan.h's Avatar
Still interested, Mr. Firechicken?
Old Oct 13, 2006 | 12:54 AM
  #60
kyle88transam's Avatar
Car: 1986 Trans Am
Engine: soon to be a iron block 5.7 lsx
Transmission: 4l80e
Axle/Gears: 9 inch
$20.00 to XXXXXXXXXXXXX for an assembled one correct, if so I'll send payment tomorrow evening
***MOD EDIT***
Editted at email address owners request.
Old Oct 13, 2006 | 10:43 AM
  #61
ryan.h's Avatar
correctamundo...
Also if you could edit out my email or change the @ to (at) so I don't get attacked by spam, I would greatly appreciate it.
Old Oct 15, 2006 | 10:36 AM
  #62
ryan.h's Avatar
Going to the post office tomorrow.....
Also, I don't know what's going on, but please don't post that you're interested unless you have an intention of following through.
Old Oct 15, 2006 | 01:50 PM
  #63
NomadTA's Avatar
Car: 11 F350 CC DRW Dsl
Is there any additional cost to ship these USPS into Canada? Don't need to get it real fast, there either Global Priority or Airmail Letter Post (up to 7 days it looks like).
I'm thinking 1 assembled adapter and 3 EEPROM's.
Steve
Old Oct 15, 2006 | 03:09 PM
  #64
ryan.h's Avatar
I've shipped a couple of these internationally by regular airmail, and it's $1 extra.
LMK, like I said I'm going to the post office tomorrow...
Old Oct 15, 2006 | 08:17 PM
  #65
NomadTA's Avatar
You have money. My PP addy is stephenc at dolphinsys do com
Ships to Caledon, ON, Canada
Steve
Old Oct 15, 2006 | 08:44 PM
  #66
ryan.h's Avatar
Will pack and ship it tomorrow morning. Thanks for your purchase!
Old Nov 1, 2006 | 02:28 PM
  #67
ryan.h's Avatar
Anybody else? Going to the post office tomorrow.......
Old Feb 5, 2007 | 11:01 PM
  #68
ryan.h's Avatar
Bump!
Just got a new shipment of boards in. Can't believe I went through them all!
Old Aug 31, 2007 | 04:27 PM
  #69
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Re: They're IN!! Memcal adapters for all!
I need two or three if you still have available.
Thanks,
Ron
Old Sep 12, 2007 | 05:17 PM
  #70
ryan.h's Avatar
Okay, they're back in stock. Returning PM's to everyone........
Old Sep 12, 2007 | 08:48 PM
  #71
paulbuiltbird's Avatar
Car: 1989 Formula 350
Engine: 350 fuel injected
Axle/Gears: 9 bolt w/370 gears
how much for your most "deluxe" package? you know,everthing needed minus the actual burner. shipped to 60173.
Old Sep 12, 2007 | 09:39 PM
  #72
ryan.h's Avatar
memcal adapter kit - $15 (+10 if you want it assembled/soldered for you)
'512 chip - $3
Old Sep 13, 2007 | 12:06 PM
  #73
I'm looking for the price of your most done up adapter with all the goodies, fully loaded, fully assembled. Memcal adapter, ZIF socket, fully assembled, fully loaded & 3 512 chips shipped to 60173. Like I was saying above, I want your most complete deluxe package. Also do you take paypal? send me the info if so.
Old Sep 13, 2007 | 06:54 PM
  #74
scuzz's Avatar
Engine: LB9
Axle/Gears: 3.55
Really nice guy to deal with.
Thanks,
Ron
Old Sep 13, 2007 | 06:56 PM
  #75
ryan.h's Avatar
ahh, gotcha...
I think I've got 1 ZIF left.
Memcal: $15
Assembly: $10
ZIF: $6
3x 512 chips: $9
Total: $40 delivered in the US. Paypal is fine. I'll send you a PM
Old Sep 17, 2007 | 06:17 PM
  #76
scuzz's Avatar
Engine: LB9
Axle/Gears: 3.55
I got my 3 adapters today, and they look great.
Thanks,
Ron
Old Oct 6, 2007 | 06:03 AM
  #77
NomadTA's Avatar
Do you have any more adapters? I bought one from you a while back but now I need another.
Old Oct 6, 2007 | 09:05 AM
  #78
ryan.h's Avatar
Sure do!
Old Oct 8, 2007 | 08:02 AM
  #79
PurpleHaze92's Avatar
Car: 1992 rs
Axle/Gears: ones that turn
ahh, gotcha...
Memcal: $15
Assembly: $10
ZIF: $6
3x 512 chips: $9
If I bought all this listed what else would i need to burn?
Im a burn virgin
Old Oct 8, 2007 | 09:48 AM
  #80
ryan.h's Avatar
Im a burn virgin
an eprom burner would be a good start.
Old Oct 9, 2007 | 08:26 AM
  #81
NomadTA's Avatar
I need one unassembled adapter (socket and header and board?). Last time it was +1$ for Canada. That would be 16$ right? Same PP addy as before?
Old Oct 16, 2007 | 11:44 PM
  #82
83MonteSS's Avatar
Memcal: $15
Assembly: $10
ZIF: $6
3x 512 chips: $9
Do you still have all of the above available? If so I'll take it. I can paypal.
Old Oct 19, 2007 | 04:35 PM
  #83
ryan.h's Avatar
Sorry for not getting back to you sooner...
I could do that. Same as before.
Originally Posted by 83MonteSS
Memcal: $15
Assembly: $10
ZIF: $6
3x 512 chips: $9
Yes, ZIF's are on order and cost $8 now. I may be running out of 512's, I'd need to check
Old Oct 19, 2007 | 05:00 PM
  #84
83MonteSS's Avatar
So if you have the 3 512's it would be 42 due to the increase in price on the ZIF? If this is correct let me know and I can send payment immediately.
Old Oct 19, 2007 | 05:41 PM
  #85
ryan.h's Avatar
Correct. I won't have the ZIF's until next week though.
Old Oct 19, 2007 | 10:41 PM
  #86
83MonteSS's Avatar
Thats cool Im going away next week for a 6-week training course in the desert so I wont be tuning anytime soon. Im sending payment now. Thanks.
Old Oct 20, 2007 | 03:36 AM
  #87
ws6gta89's Avatar
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
ok i really dont understand any of this but there is a local guy on here that is willing to burn chips for free but the only catch is it will be his first time (i believe)so i was wondering could i buy one of these and use to burn on so that i could just put my stock chip back in if we have any problems? thanx Charles
Old Oct 22, 2007 | 09:23 AM
  #88
ryan.h's Avatar
I do not have your payment?
If you wanted to go back to stock, all it would take is removing the adapter and plugging the old memcal back in. Or installing a stock chip. Whatever's easier.
Old Oct 23, 2007 | 06:45 PM
  #89
ryan.h's Avatar
NomadTA - got your payment, ships tomorrow.
Old Nov 18, 2007 | 10:11 AM
  #90
jbpnumber03's Avatar
pm sent
Old Nov 18, 2007 | 10:19 AM
  #91
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
I gotta latch on to this one; tuning begins soon...
Are you up on all of your stock, ryan h?
Old Nov 19, 2007 | 10:35 PM
  #92
ryan.h's Avatar
Hi Guys-
Sorry for not getting back to you sooner........ incredibly busy here lately. I got your emails and PMs.
I do have ZIFs and memcal adapters on hand. I don't have any chips at the moment. If you want a kit that you solder yourself - I can send it ASAP. If you want an "assembled" kit that you just plug in and go, it's going to have to wait. (At least another week)
Old Nov 27, 2007 | 12:37 PM
  #93
SLP_GTA's Avatar
Hi Guys-
looking for the complete set up with five addtional 512s chip. lIM me when you have them in stock.
Old Dec 7, 2007 | 09:51 AM
  #94
mk10842766's Avatar
ryan, if you have a couple assembled, with a zif, let me know, and I'll send you a paypal asap...don't need any chips, got plenty.
Cheers,
Michael
Old Jan 23, 2008 | 01:04 PM
  #95
SLP_GTA's Avatar
IM sent
Old Jan 31, 2008 | 08:10 AM
  #96
drowning in tbi's Avatar
Do you have any assembled units in stock? Is the price still $25.00 delivered? Thanks.
Old Feb 25, 2008 | 04:00 PM
  #97
grosss's Avatar
PM Sent!
Old May 28, 2008 | 11:01 PM
  #98
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
Are you still selling these units anymore? PM Sent
Old Jun 22, 2008 | 01:00 AM
  #99
BlueIroc-Z's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
Same question... I am in the market for one...
(also sent PM)
Old Jun 23, 2008 | 05:33 PM
  #100
kanmudhog's Avatar
Car: 89 formula ws6
Engine: yes
Transmission: yes
Axle/Gears: both
Ryan where are you ??? , I need stuff .
