355 block,TPI setup,heads,and more!!
Old Aug 25, 2006 | 08:09 PM
LT1ROC's Avatar
I currently have some stuff I'm looking to sell,trade or a combo of both.I'll start with what I have to get rid of,and then a list of what I'm looking for.I'm flexible ,so any offers will be entertained...thanks for lookin'!.....First off,I have a 1979 3970010 high nickel 350 block(010 stamping).It had slugs punched .30 over in it when disassembled.This motor did run and actually quite strong.It did however have a rod knock and the lower(mains) bearings were wiped.It should just need a good cleaning and hone,and I think it could be re-slugged @ .30.If not ,.40 very easy.The guy that owned the vehicle I pulled it from had a loose valve cover,and didn't believe in changing his oil it looks like.And he used Fram filters(ughh)...this is worth $350-$500 or better as a core at worst and is high nickel,so desirable...even as a core somewhere I could throw in the old rotating assembly and it's worth that...It is bare right now.I also have a couple of TPI setups,almost complete.No wiring or harness,or ecm's,but one 86-and older baseplate,and two 87-and newer baseplates,two fuel rails (with cold start) two sets of runners(one excellent,one with small dents)and I've seen some dented ones..lol.Two plenums,two throttle bodies,all oem stuff.Water necks,one re-man'd distributor(never installed,newly finished(A1 Cardone),one OE distributor,both small cap HEI.Miscellaneous sensors,etc...I have alot of stuff for these setups,so if you think you might need it,or I hven't listed it,please ask because I probably do.Price wise $150 and up per setup depending on what all is wanted( I can part seperately possibly).I have two matching high compression circle track spec 305 heads.60cc's(??) I believe.Exact casting 354434.These are circle/dirt track spec 305 heads,I ran the numbers after I got 'em,and currently don't have a home for 'em so hopefully somebody can use them...offers??I have a Rochester non-computer controlled Q-jet off a '79ish 350 also for sale/trade...recommend rebuild,but ran o.k.on this motor I disassembled...offer$'s...I also have a Zexel Torsen differential with axles taken from a '98 Trans Am...same one SLP was selling for $100..I'd take $125 with both axles for all 3 pieces plus shipping.......and that's all I have to clear out for now....please ask(PM or e-mail me) if you think I might have it and I'll see my garage needs to be cleaned ....Now for what I'm looking for: I need a nice(doesn't have to be perfect) Dash pad for my '92 B4C 1LE RS,a grey headliner for it,and I'd like either a very nice driver side seat ,or matching set(cloth)seats,vintage '92...(darn gunbelt rips..lol).. OR a 4th gen cloth multi tone or solid tone grey to upgrade too.(full set or just fronts)Wonder bar,and subframe connectors.I'm also looking for a couple bigger items too: fiberglass hood(ss type or flat oem replica),headers and y-pipe,this is dual cat,but would consider swapping to a 3" single....and partial trades plus cash for a roller 350/355...possible 400 blocks worth rebuilding or running,LT1's and anyone who might have a 454 short or long block that isn't a boat anchor would be considered...if you have something else of interest let me know...Thanks all for reading my short novel....Almost forgot...located in Austin,Texas.....................Talk to y'all later!!
.............Jesse
Old Aug 25, 2006 | 08:11 PM
LT1ROC's Avatar
Can and will post pics upon request....just hafta upload 'em....Thanks!!
Old Aug 25, 2006 | 10:20 PM
droppedbagged72's Avatar
PM me a complete list of all TPI stuff, and a price for all of it together. Thanks.
Old Aug 27, 2006 | 06:41 PM
LT1ROC's Avatar
Sold block and one TPI setup locally.....I still have the non-computer controlled Rochester Quad,'98 T/A Zexel w/ axles,305 60cc(??) heads,and one TPI setup(but two more baseplates) for sale.....TPI stuff left consists of one pre 86 baseplate,one 87 and up baseplate,runners,plenum,TB,EGR's,waterneck,distributor,fuel rails w/ injectors(19lb/hr) w/metal lines all the way to were the soft lines hook up.I also have one re-maned distributor(both of these are small cap HEI),and all replacement sensors new in the boxes.I can even throw in a Fel-Pro gasket set if someone wants a complete set.You only need to supply your own harness,ecm,mass air sensor,and air filter ***'y....I have the hard parts left....PM me with any offers if someone can use any of this,if not I'll hold onto it,I'd also be willing to trade for a nice dashpad,or seats.....Thanks!!
Old Aug 29, 2006 | 07:36 AM
LT1ROC's Avatar
Old Sep 2, 2006 | 12:52 PM
LT1ROC's Avatar
Reddeath210
Oct 6, 2015 08:20 AM
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
