FREE 10 BOLT 3.42 DISC REAR END! IN CT
Car: 1985 IROC / 1986 SC
Engine: 305 TPI / 2.8 MFI
Transmission: 700R4's
Axle/Gears: 3.27 Posi / 3.42 Open
Just like the title says. All of the brake hardware is gone, this is the housing, axles, center section. Come and pick it up and its yours. Worked great with no noises, replaced because I swapped it for a posi rear and the pinion seal was leaking, easy fix. Come get it!
It is not a posi, GM made plenty of 3.42 open disc brake rears. It has 104,000 miles on it but worked fine with no noises.
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
if youll strip it to just a bare housing ill come get it, i just need a disk housing. theres no disc brake stuff on the rear right? lemmie kno.
matt
matt
No, the brakes are gone, I have no idea how to strip it, never took one apart, your welcome to it if you want to strip it down, then you could sell the axles and gears.
where in ct are you and what year is it out of
matt
matt
Transmission: A4
if someone picks this up and lives in MASS or RI then let me know if you dontneed the axles. I will take them as long as all the studs are on and they are straight
im prolly gonna be gettin it this week, all i need is the housing so the axles r urs if you want em, 26 spline tho.
matt
matt
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
i am in eastern ct and I am going to be getting rid of a 89 10 bolt chicken legger here in a little wile. if you need axles or what ever
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
