Moser 12-bolt 3.73s, 4th gen wheel offset
Old Oct 11, 2006 | 02:00 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Moser 12-bolt
30-spline axles
Eaton posi witih 3.73 gears
Set up for 4th gen with provisions for 4-channel ABS/TCS
3.25" ARP wheel studs (stock thread)
Chromed stamped steel cover
Spicer 1310 yoke
I bought this for $1900 less than two weeks ago with 8k miles on it. I've since decided to go with a 9" instead.
I purchased two new axle bearings for it ($40ea) and the conversion U-joint ($25).
All you'll need to do is swap your U-joint, and have the bearings pressed on the axles (need to re-use your stock LS1 backing plates) and you're good to install it.
I want to get $1900 out of it. I'm already taking over a hundred dollar loss and won't take any less. For $1900 + $40 bearing install, you're getting a bolt-in 12-bolt with 8k miles on gears/posi and brand new wheel bearings and U-joint. Can't get much better than that.
Its currently sitting in my garage in Bloomingdale, IL 60108. I will not ship it, and you need to pick it up as I have no means of delivering it anywhere.
Old Oct 11, 2006 | 08:32 PM
Car: 1997 Corvette
ttt
Old Oct 11, 2006 | 11:34 PM
Pwebbz28's Avatar
oops wrong thread
Omega
Oct 1, 2015 02:20 PM
cam-mike
Aug 24, 2015 07:23 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
