TPI setup
Old Nov 19, 2006 | 02:36 PM
leathalirocz's Avatar
Car: 1988 Irocz
Engine: 355 Stealthram
Transmission: 5speed
Axle/Gears: Stock 10bolt 3.73 posi
TPI setup
I have my tuneport for sale off my 88 Camaro since i went HSR. It includes the base manifold, runners, plenum, rails with the metal lines & non adjustable regulator, cold start injector. I had it stripped and painted high temp ceramic silver then coated in high temp ceramic clear. All gasket surfaces are stripped clean, gaskets not included. Also does not have the piece that screws in the middle of the schrader valve {dont know what i did with it since i was running NOS when it was still on my car} you can pick them up anywhere though. Asking $130.00 shipped anywhere in the USA. There was only one dent on one runner that i did get most of it back out {doesn't look bad as you can see from the pic}. I do have many more pic of the parts seperate that i can email you if you need to see.
Attached Thumbnails TPI setup-mvc-013f.jpg   TPI setup-mvc-015f.jpg   TPI setup-mvc-009f.jpg
Old Nov 19, 2006 | 03:39 PM
ddr698's Avatar
If you take paypal ill take it, lmk, thanks,
Dan
stalkier
Dec 6, 2015 11:25 PM
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
