LT1 Conversion Intake
Old Nov 29, 2006 | 12:32 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
EVERYTHING LISTED IN THIS THREAD HAS BEEN SOLD!!!
I've got a slightly used LT1 conversion intake, was one of the last ones done by John Millican before he sold the business. Has the 58mm TB bores, vertical water port fittings on the back, distributor tie down, etc. Intake is ready to use.
Asking $275 plus shipping. Paypal perferred, and I'll cover the fees on it. Does not include the fuel lines or remote thermostat housing, but does include a used set of fuel rails and stock injectors.
Add $35 if you want a set of polished fuel rails that I have.
Add $40 for an adjustable fuel pressure regulator that I have.
- Vern
Old Nov 29, 2006 | 10:48 AM
vernw's Avatar
There was some confusion on a combined deal with other parts and this intake is now avaialble and for sale again.
Old Nov 30, 2006 | 11:15 AM
vernw's Avatar
AFPR has been sold - Thanks Bobby (simz28)!!!
I do have one more LT1 AFPR - it's a Kirban billet AFPR - $75 shipped for that one (sells for over $100 new)
Old Nov 30, 2006 | 12:42 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Got a pic of the Kirban billet AFPR ?
Old Nov 30, 2006 | 01:17 PM
vernw's Avatar
Sure, send me an email address and I'll send them to you.
Old Nov 30, 2006 | 01:24 PM
vernw's Avatar
There was some confusion on a combined deal with other parts and the intake is now avaialble and for sale again.
The polished fuel rails and Kirban AFR are also still available.
Old Nov 30, 2006 | 05:09 PM
ajk511's Avatar
Car: 1991 z28
Im intesested in the intke and fuel rails. what else would i need to get it running on my L98?
Old Nov 30, 2006 | 11:00 PM
vernw's Avatar
Well, it comes with used factory set of fuel rails and stock injectors, although I'd consider getting them cleaned and flow tested (or replaced with some SVO injectors). You can re-use your existing distributor, throttle body and TB sensors, map sensor, PCV valve, etc. You would need to get a remote thermostat housing (from either LT1intake.com or summit racing), a couple of heater hoses from NAPA, and some small-head intake bolts and you should be ready to go. I'd also recommend getting an adjustable fuel pressure regulator and a custom prom unless you can tune it yourself.
Old Dec 1, 2006 | 09:24 AM
vernw's Avatar
This is going to eBay soon if no one here wants it.
Old Dec 1, 2006 | 03:09 PM
vernw's Avatar
Deal pending on the LT1 intake conversion
Polished fuel rails and Kirban AFPR for LT1 are still available
Old Dec 5, 2006 | 11:07 PM
vernw's Avatar
LT1 Conversion intake - SOLD!!!
Polished Fuel Rails and Kirban AFPR - SOLD!!!
92projectcamaro
Jan 18, 2016 08:00 AM
86CamaroDan
Sep 29, 2015 10:08 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
