Single electric fan and shroud
Old Jan 26, 2007 | 12:26 AM
droppedbagged72's Avatar
Off of a 305 RS. Works good, comes with shroud. $25
Old Jan 31, 2007 | 08:36 PM
northerncalkitt's Avatar
Car: 1984 Pontiac T/A[ K.I.T.T]
Engine: 350 Quadrajet carb.
Transmission: 700 R4
Hello... Do you have pics of it? I would like to see it...
Thank you
Marty
Old Feb 27, 2007 | 02:47 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
iuyjuhtkig
Old Feb 27, 2007 | 06:49 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
I did the swap in my 85. Shroud and fan should be three pieces, lower shroud, fan mount/assembly and upper shroud.
Uses the same screws and brackets that the mechanical shroud uses. The bottom piece mounts inside the lower lip not outside like the mechanical shroud, so you may have to remove the clips from the body so the screws can pass thru and engage the lower shroud clips. To do a stock style swap you'll also need the fan relay and pigtail from the drivers side firewall and the temp switch and pigtail. Don't forget the motor pigtail. These pigtails are difficult to locate, although the temp switch pigtail is available from TPI Parts (sp?).
Old Feb 27, 2007 | 12:39 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
ok good info thanks
i dont have my bolts for mounting the mechanical shroud in, they were removed from the car before i even got it, and this was over 6 years ago, but i probably have them around from past part outs, but i wouldnt know which ones they are now
also for wiring i would just go with a toggle and relay
because i am running non computer LG4
i see that there is a temp spade connector in the radiator tank
is that for ground side of the fan circuit ? or for the ECM temp ?
for the fan right ?
thanks
Bubbajones_ya
Jul 6, 2024 08:32 PM
codeysabatini
Nov 10, 2015 04:07 PM
tommy z-28
Oct 6, 2015 10:58 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
