355 TPI engine FS
Old Feb 11, 2007 | 01:15 AM
Kennerz's Avatar
Car: 88 5.7 Iroc, 2000 SS
Engine: Vortec Hot cam TPI/LS1
Transmission: Pro-Built/T-56
355 TPI engine FS
I have a 355 engine for sale.
Details:
Heavy duty 87' - up 4bolt - hydrolic roller block
Ported L98 Iron Head
Double valve springs
Includes ported 88' tpi manifold
comp 1.52 roller rockers
comp chromoly push rods
comp XE264HR cam
Scat crank/ rods -stock replacement
milodon pan/windage tray
High pressure oil pump
stewart water pump
about 10k or less on motor
motor would easily beat stock turbo supra's(93- up) lt1's ran well , has incredible mid range.
needs new cam/main bearings(will explain)
$600 or ??? no parting out, no trades
in southern cal (sd county ) area
Old Feb 11, 2007 | 01:28 PM
ling427ttvette's Avatar
Car: 1983 Camaro Z28/1999 Cavalier
What kind of power would you say it has? I've been wanting to save up for a 383 swap, but this one is already put together and is cheaper than a 383 swap.
Why does it need a new cam and main bearings though?
Old Feb 11, 2007 | 03:18 PM
Kennerz's Avatar
probably about 265~270RWHP with a stock TB, and plenum so about 315~320 Flywheel. WIth a carb it would make more power.
Stupid me I for got to drain the intake, and some water got in the bottom end- I flushed it well. but when I started it again it had low oil pressure, no knock or anything, just was only pulling about 35psi, so I figure it needs new bearings. THis motor would be an easy re-build. I'm being 100% honest-no bull. or you could add a stroker crank and get a 390 or what ever size it would be.
Old Feb 11, 2007 | 03:35 PM
Really that doesn't sound too bad, it sucks that your so far away from me. Sounds like it would be a good starter motor to get some power out of instead of my little 305. I couldn't imagine paying shipping on that from there to here.
Old Feb 12, 2007 | 12:57 PM
mfelix's Avatar
Car: 1987 iroc z
Transmission: auto
Axle/Gears: 373
do you have any pics if so could you please email them to me mfelix@clarion.com thank you
Old Feb 12, 2007 | 02:46 PM
Kennerz's Avatar
mfelix,
I'll have to take some, I'll try to get them to you in a day or so (I don't get home till after dark)
I'll send my number in the PM if you want to ask some questions....
Old Feb 13, 2007 | 03:17 PM
Kennerz's Avatar
Bump....
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Sep 3, 2015 10:56 PM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
