4spd manual out of 82' firebird SE
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
up for sale is a used 4spd manual setup. i pulled the trans out of a 82 firebird SE that had the LG4 motor. i have almost all the parts to do a manual trans swap except for the torque arm and mount, flywheel, and clutch assembly
the trans shifted fine during the short time i drove it, but there is no warrenty with these parts since they are very old. i am located in northern DE, pickup only of course. $75 takes everything i have with this trans
thanks
thanks
Car: 84 trans am
Transmission: built 700r4
hey is this a saginaw or t-10? i dont know too much about the 4 speeds as aposed to the t5's but about how much power can they handle. i know a t5 will take up to around 300 safely but i dont know about these i heard the t-t-10' s are good but the sagniaws are crap.
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
i honestly dont know which trans this is or how much power they can handle. i simply pulled it and all the related parts from the donor car
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
nah... too many parts, too much weight, too much hassle. itll cost a bundle too, probably more than what im asking for the stuff itself
Im very interested do u have pics of it by any chance,maybe numbers off the trans does it come with the clutch z-bar linkage, im in CT will be willing to pick up ASAP
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
i could try to get some numbers off it, its pretty dirty tho. if i have time to clean it up a bit ill put some numbers up. i dont have any pics tho
this is what i have:
- trans
- bellhousing
- clutch fork
- shifter, ****, and boot
- console plate (screw holes are cracked)
- Z bar linkage
- clutch/brake pedal assembly
- all related nuts, and bolts, and fasteners
- driveshaft
- crossmember
you would need to supply a flywheel, clutch kit, torque arm mounting bracket, and torque arm to install this transmission. i know the torque arm and mounting bracket are 82/83 specific due to this trans being shorter than the 700R4s and T5s. the arm and mount could come off any 82/83 with the 4spd manual or 3spd auto
- trans
- bellhousing
- clutch fork
- Z bar linkage
- driveshaft
- crossmember
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
is reverse in the top left or bottom left?
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If the trans has an aluminum case, its a T10. If its iron, its a saginaw.
not always true super t-10s came with irom cases, the one in my original 4 speed car is an iron case,
they also used a low 3.42 first gear matched to a high 273 rear end in order to meet the gas standards of the early 80s
No 3rdgen F-body came with an iron T10. Any iron-case 4-spd with all the necessary provisions for a 3rdgen chassis will be a saginaw.
Car: 1982 Trans Am
Engine: Chevy 305 for now
Transmission: Borg Warner T-10
Re: 4spd manual out of 82' firebird SE
is the trans a t-10 or a saginaw? did he ever reply if reverse is up and to the left or down and to the left?
i have a saginaw 4spd in my trans am. its not too bad a trans. its only got 57,000 original miles on it. ive heard it can handle about 350 horse safely.
Car: 63 Nova SS, 91 Camaro Rs
1992 Trans Am
May 10, 2023 07:19 PM
bjpotter
Jan 22, 2019 12:27 PM
