Complete V6 T5 Swap Kit
Old Feb 28, 2007 | 03:36 PM
CorViparo's Avatar
Car: 1989 Camaro RS
Engine: Turbocharged 350
Transmission: Viper T56
Axle/Gears: LS1 3.23 Posi
I have everything needed to swap a T5 into a V6 car if anyone is interested. All parts came from the same '92 Camaro. Everything is there from pedals to starter and driveshaft. All the bolts are bagged and labeled to make installation as easy as possible. I would like to get $350 for everything. Anybody interested??
Old Mar 15, 2007 | 10:52 AM
bcpower's Avatar
Car: 84 and 82 camaro
What makes it only for a V6?
Old Mar 15, 2007 | 07:18 PM
CorViparo's Avatar
Car: 1989 Camaro RS
The gear ratios in the V6 T5 are different than the V8 T5. And the input shaft is a 14(16 maybe?) spline vs. the 28 spline V8. The clutch, pressure plate, and flywheel are also unique to a V6.
Old Mar 15, 2007 | 07:24 PM
CorViparo's Avatar
Car: 1989 Camaro RS
To define the contents of the "kit", here is what is included:
-Clutch hydralics (master/slave)
-Pedals
-Flywheel/Pressure Plate/Clutch disk
-Bellhousing
-Trans assy.
-Shifter
-Driveshaft (if needed)
-Starter
-Crossmember/mount
-All required bolts (bagged and labeled)
anesthes
Sep 30, 2015 07:48 AM
BOOT77
Sep 16, 2015 08:37 PM
eduardosac
Sep 16, 2015 02:18 PM
Trevor Tarry
Sep 15, 2015 02:04 AM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
