parting 89 formula 350
Car: 89 iroc/90 iroc conv./06 ram
Axle/Gears: 3.27/3.27/3.91
parting whole car. 5.7 tpi motor $600, hear it run. 700r4 tranny $100, disk brake posi with pbr calipers, complete $250. dual fan setup $75. won't ship the big stuff.
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
Re: parting 89 formula 350
Hi,
What color is the interior? Does it have the 140mph speedo? I am looking for the cluster, overhead B pillar plastic, and the plastic clips for the front of the headliner.
Too bad you were'nt closer I'd get a bunch of bigger stuff.
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
do you still have the dual fan? if so how much to ship to 68113?
$80 shipped for the dual fan setup.
i will check on the gears and let you know by wednesday.
Car: 88 GTA
Is the fan setup spoken for? Any chance you could inclue the two connectors to the fans and some of the wire for me to splice in? Let me know. Thanks.
Car: 91 Trans Am, 88 GTA, 90 Formula 350
Engine: 305TPI, 350TPI, 350TPI
Transmission: 700R-4
Axle/Gears: 3.27, 3.27, 3.23
Do you have the computer with chip for the 89 350 TPI?
thanks, john
i do have the stock exhaust manifolds for $30. or a set of headers and a y-pipe for $100 plus shipping on both. the y-pipe has no cat. you can buy a hi-flow cat for about $60.
$50 for the 140mph/8000 tach gauge cluster shipped in the u.s.
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
need the engine harness, if it's a+ condition, from computer to bulkheads and from bulkhead to bulkhead, let me know how much you'll take for it
thanks!
adam
thanks!
adam
Car: 86' Z28 Camaro
Engine: 357 TPI -- Dart Heads -- Voodoo Cam
Transmission: Built 700r4
Axle/Gears: 3.23 Posi
Which heads are on the motor?? If they are the 083 casting heads, how much shipped to 58079??? Thanks!
they are 083 heads. $100 plus shipping. i'll check on shipping if interested
so you need the engine harness and under the dash harness? $200 shipped
do you need the engine and under the dash harness? or just the engine?
Car: 1991 FORMULA
i need the short harness that connects the computer to the bulkhead coonector at the kickpanel, as well as the engine harness from bulk connector to bulk connector, mine originally came with tpi, but like a jackass i cut the hell out of it when i went to carb, wanting to try injection again, so the harness should bolt right up if i can get one from an 89 tpi setup...
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Axle/Gears: 3.27 BW
Would you be willing to sell the serpentine setup off of the engine? Or is that a no-go, as you want people to be able to hear it run?
i will sell the complete serpintine setup with the bolts and all acess. for $150 shipped
thanks, john
Last edited by liteumup387; Apr 8, 2007 at 09:06 PM. Reason: listed wrong information
it would be around $40 to ship the y-pipe and headers. if you throw me your e-mail i'll send you pics.
i think they are hookers. no airtube. i do have some edelbrocks with the air tubes. no y-pipe. for $50 shipped
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
i think ill take em, do u know the part #? i want to make sure i can get the correct y-pipe
how bout the hooker part # does that have the y?
Car: 89 formula, 89 Cadillac Brougham
Engine: 355,HSR,patriot alum. heads,TFS cam
Transmission: 700r4, 2500 B&M stall, shift kit
Axle/Gears: 3.73 ten bolt, powertrax locker
what color is the interior?
Car: Miss my thirdgen
Engine: Looking again
Do you have the oil cooler lines from the tranny to the oil filter? If so would you sale them and how much?
Thanks,
Scott
Thanks,
Scott
interested in either set of headers, pics to nismo98b14@hotmail.com please.
hooker has the y without the cat. the edelbrock, i have no idea of the part #.
harness under the hood is a 87-88. with cold start.
Last edited by 89irocz355; Apr 10, 2007 at 02:59 PM. Reason: Automerged Doublepost
Car: 1989 T/A
i will prob take hookers and y-pipe, please send pics to dambodambodambo@yahoo.com, and a way to reach u. thanx...............
