305 TPI MAF 700r4 Prom
Old Apr 23, 2007 | 07:31 PM
86z28iroc-z's Avatar
Car: 86' Z28 Camaro
Engine: 357 TPI -- Dart Heads -- Voodoo Cam
Transmission: Built 700r4
Axle/Gears: 3.23 Posi
305 TPI MAF 700r4 Prom $50 plus shipping!
Almost brand new 305 TPI MAF 700r4 prom which I purchased from a GM dealer a few months ago. AC DELCO part number 01228291
I'm converting to 350 so I won't be needing this anymore. It's only been used a few hours.
$50 plus shipping, paid 90+ from gm dealer a few months ago.
This chip fixes these known problems with the earlier chips.
New service calibrators (Ref: Called Mem-Cal In Shop Manual) have been
released for the 1986 Firebirds with the 5.OL TPI engine. These new
calibrators will address the following customer comments:
1. "Rough Idle" on both hot and cold engine - the idle speed is raised to 650
plus or minus 50 RPM.
2. "Chuggle or Shudder" at low speeds - torque converter clutch (TCC)
engagement speed is raised to 41 MPH.
3. "Hesitation" on light acceleration with a hot engine.
4. "Cold Driveability" - New calibration eliminates light to moderate sag on
cold driveaway.
5. "Service Engine Soon” Lights - Eliminates the following false Codes:
A. Code 32 - EGR System failure
B. Code 33 - Mass Airflow Sensor Voltage High
C. Code 34 - Mass Airflow Sensor Voltage Low
D. Code 43 - Electronic Spark Control
E. Code 44 - Lean Exhaust Indication
Old May 12, 2007 | 02:25 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Re: 305 TPI MAF 700r4 Prom
how much did u pay for it?
Old May 12, 2007 | 12:47 PM
Car: 86' Z28 Camaro
It was 90 bux brand new a few months ago at a GM dealership.
Old Aug 30, 2007 | 10:50 AM
Car: 86' Z28 Camaro
Bump
BlueIroc-Z
Jun 9, 2019 03:22 AM
NBrehm
Aug 25, 2015 11:49 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
