telling the differnce between 9 bolt 2 and 3 series carrier
Old Apr 30, 2007 | 06:05 PM
lt1srule's Avatar
Car: 95z,94z,88iroc
Engine: lt15.7,lt15.7,5.7TPI
Transmission: Auto,6sp.Auto
Axle/Gears: 3.42,3.42,3.27
is there numbers on the carrier to know the differnce.
Old Apr 30, 2007 | 06:55 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Re: telling the differnce between 9 bolt 2 and 3 series carrier
If you only have the carrier, no gears(to count) and don't know the part numbers you can measure the offset of the ring gear mounting surface in relation to the center of the crosspin. The 3 series should measure aprox 1.875" and the 2 series with the bigger offset should measure aprox 2.1875".
Old Apr 30, 2007 | 07:02 PM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
sounds right.... I have heard that a 7mm spacer as a shim, or washers will work.
MILEAGE MAY VARY!
hectre13
Dec 11, 2023 08:14 AM
theshackle
Mar 5, 2017 06:37 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
hectre13
Aug 26, 2015 08:17 AM
knight72
Aug 10, 2015 09:32 PM
