Selling the eng parts I purchased to rebuild my 88 L-98 since I ended up scrapping that project. If you're into rebuilding engines or getting ready to rebuild yours soon, now's the time to save some money at my expense. All parts are new in box/original packaging with the exception of #1 and #7 below. #1 - I was told has 5,000 miles on it and it looks new. #7 - One Piece RMS crank from my 90 L-98 I was going to use, had 140,000 miles on it with standard journals.
1. Cloyes True Roller Timing Chain - CLO-9-3157 (used) sold new for $97.39, has <5,000 miles. Bought used for $35.00.
2. Eagle SIR I-Beam Connecting Rods - ESP-SIR5700BPLW - 565 Grams, new in box... $235.95
3. Sealed Power Pistons - H-345NP (+.030) - Flat top, 4-valve relief, press fit pin, set of 8, new in box... $96.00
4. Clevite-77, Main Bearing Set, MS-909P - New in Box... $22.00
5. Clevite-77, Rod Bearing Set, CB-663P - New in Box... $22.00
6. Sealed Power Rings - E-251K - New in Box... $35.99
7. Stock, One piece RMS Crank (Standard, not turned, used)
Parts were purchased to rebuild an 88 L-98 (350, 5.7). The pistons/rings are .030 over, the crank/rod journals are standard. Spent over $450.00 on everything, I'd prefer to sell everything above for $250.00 OBO plus shipping.
Questions or pics? Let me know...
Magman
Magman
Brisk
close
- Join DateJul 2004
- LocationBeautiful BC
- iTrader Positive Feedback96
- iTrader Feedback Score(25)
- Car'88 IROC-Z / '91 Z28 / '91 GTA
- EngineLT4 Hot Cam 305 / L98 355 / MR 383
- Transmission5-spd / 700R4 / 700R4
- Axle/Gears3:45 / 3:23 / 3:23
- Liked:0 Times in 0 Posts
what volume are the pistons.. meaning what would the compression ratio be with stock heads?
Comp ratio should be close to 9:1, you can have the heads milled/resurfaced to bump it up. Here's a link to them on Summit (mine are +.030).
http://store.summitracing.com/partde...P&autoview=sku
Duts87ss
close
- Join DateAug 2005
- LocationOcean Springs, MS
- iTrader Positive Feedback100
- iTrader Feedback Score(10)
- Car1987 Monte Carlo SS
- EngineHSR 383 AFR180/268XFI EBL
- Transmission200-4R, Edge 2800 L/U
- Axle/Gears7.5/3.73/PowerTrax No-Slip
I may be interested. Are the rod and main bearings for a standard crank or a 10-10 (etc.) crank?
Give me a shipping estimate to 39564.
Duts87ss - The bearings are standard size. I'll have to get back to you on a shipping estimate on Sunday (heading out of town tonight).
footjoy - make it $225.00 plus shipping and you've got a deal. The rods alone are worth more...
I'm starting to think I should just look for a block
Duts87ss - PM sent
How about 175 for 1,2,4,5, and 6? How soon do you need to get rid of it? if you can hold it for a couple weeks I'll get these items from you. PM me and let me know
How much for number 1 shipped to 23072? Will you accept paypal? Thanks!
Hello interested in the main and rod bearings if still available. If so, how much shipped to Thunder Bay, ON P7E4L8. Thanks, John
Sale pending on all parts.
u got a PM
