Built 383 complete
Car: 1986 IROC, 2017 Silverado
Engine: 7.0L, 6.2L
Transmission: Tremec Magnum, 8L80
Axle/Gears: 3:23, 3:55
Built 383 complete
Chevy 383cid 4.030 one piece seal for sale
The motor was decked to 0 and squared; the main journals were reground and aligned for the new main caps. The motor was built to go into my IROC, but I have decided to change my path with the car. The motor was built March of 2006 and has sat on the engine stand waiting for me to finish the car. Unless specified, all parts are new. There was nothing missed in the building of the motor, no shortcuts, what so ever, this motor was built to run hard.
At this time nothing will be sold separate, unless the block and rotating assembly sell, don’t ask. I will notify via post that it the assembly will be split apart. The buyer is responsible for pick-up of the motor. I have the receipts for the motor from the engine builder, they will be provided when the engine is sold.
Miloden Splayed 4 bolt main caps
Eagle H-Beam rods
Eagle Light Weight forged Crank
SRP -5CC forged pistons
Polished Floating Wrist Pins
ARP rod bolts
ARP Splayed cap kit
ARP Head stud kit
Blok hardener to the bottom of the freeze plug ¼ fill
Total seal gapless rings
Roller Timing chain w/ aluminum timing cover
HD bearings used
Moroso Solid motor mounts.
Canton Road Race Oil pan & pick-up
Edit - Meziere heavy duty electric water pump **
Edit - MSD 8366 - Billet Distributor **
Edit - Holley 58mm Throttlebody **
Air Flow Research 190 heads shaved to 58cc chambers, angle plug, perimeter bolt – re-decked 6K miles on the heads.
Titanium Intake and Exhaust valves 2.02/1.60 – Nascar Valves
Titanium retainers
Comp Valve springs, good to .600 lift
Comp Magnum 1.5 Roller Rockers or Comp 1.6 Roller Rockers
Comp CC306 Cam
Edit - Comp Cams "R" Lifters
Custom Aluminum valve covers to clear the LT- Alternator (Like Canton’s). They were checked for leaks after welding the valve cover.
Hooker Super Comp headers (Jet hot Black coating(higher temp))
Mini-ram intake w/ adjustable fuel pressure regulator, #6 AN fittings on the back side with the lines to hook into a 3rd generation Camaro or Firebird. 6000 miles on the intake
The motor was set to run a LT-1 serpentine set-up so here are the following items also;
ATI Superdamper Harmonic part #917271 balancer w/ aluminum hub for a LT-1
LT-1 Accessory Bracket - Used
LT-1 Alternator - Used
Complete set-up $7000 obo, reasonable offers only,
Eagle H-Beam rods
ARP rod bolts
ARP Splayed cap kit
ARP Head stud kit
HD bearings used
Titanium retainers
Comp CC306 Cam
Terrell351
Jun 13, 2021 01:13 PM
Mickeyruder
Sep 2, 2015 02:45 PM
