C4 Non HD Conversion Brackets
Old Jul 23, 2007 | 02:51 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Selling my NON-HD 12" C4 Conversion Brackets with Mounting Bolts. $70 Shipped OBO.
Picture Shows them Bolted to the Spindles not included.
Old Jul 23, 2007 | 03:18 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: C4 Non HD Conversion Brackets
I'll give you $60 shipped if you divulge the modifications necessary to the spindle to get them to work. It seems to be a secret no one is willing to share.
Old Jul 23, 2007 | 04:55 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
$65 shipped and you have a deal. Mod to spindle is easy. Basicly are cutting off the ears where the stock caliper bolted up and removing the dust shield. Then drill and tap the dust shield holes for the larger bolts. I can give you the specifics and will have to look for the size tap to use............jt
Old Jul 23, 2007 | 05:43 PM
wesilva's Avatar
Transmission: 200R4
Perfect. Details with pictures would be great!! PayPal or Money order...your call. Thanks!!
Just to make sure were on the same page. These are the brackets to mount C4 12" rotor calipers. The 12" rotors used are C4 rear rotors ......correct?
Old Jul 23, 2007 | 05:52 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
That is correct...C4 12" Brakes with rear rotors to be used on the front of the F-Body. Paypal would be fine at jtmiller92@adelphia.net or send a Money Order to the following. I'll work on getting all the directions put together for you. I can sell my modded spindles for $75 if interested......jt
Jeremy Miller
117 Briarwood Dr
Nicholasville, KY 40356
Old Jul 24, 2007 | 09:39 AM
wesilva's Avatar
Transmission: 200R4
Thanks, Jeremy. I will have it out today via PayPal.
Sincere thanks for the spindle offer but I work at a machine shop. If you give me good directions and a pic or two, I will figure it out. But.....you can make me a screaming deal and include the Earl braided brake lines. What can you do for me in a package deal.
Old Jul 24, 2007 | 01:57 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Thats cool, thought I would offer. lol I would take $50 for the lines if you want. LMK..........jt
Old Jul 24, 2007 | 02:08 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Here are some links the the spindle mods with detailed drawings and pictures. 1LE spindle mod was the search I used. All brake conversions use these same mods with the exception to cutting the bump stop off the spindle for the C4 brakes. Drill the dust shield holes with a 13/32 bit then tap them with a 12mm x 1.75 tap.
https://www.thirdgen.org/forums/brak...le-mod-qs.html
Old Jul 24, 2007 | 06:29 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Brackets are sold. Thanks........jt
Linson
Oct 24, 2025 02:00 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
armybyrd
Sep 26, 2015 03:37 PM
