355 longblock AFR 210 heads
Old Aug 13, 2007 | 01:13 PM
superirocz's Avatar
This motor was assembled by one of the best mopar builders in the country and has been featured in hod rods "engine builders contest" taking 3rd place
It is a 4 bolt 355 sbc studed block with trw forged pistons reconditioned crank/rods
Summit cam not real huge. Heads are AFR 210 heads with 1.6 RRs. The engine is about 9:1 compresion and has about 2000 miles on it and works great. I have this in my car and ran about 6-8 psi with my turbo setup. This would make a nice na motor or a great low boost street engine under 15psi. Motor has ARP bolts throughout. AFR Heads alone cost me $1460. I do have an extra set of valve springs if you wanted to run a high lift cam up to 650 lift
Includes oil pan tapped with an return lines and billet timing chain cover, new water pump.
Looking to get $3500
email me at matt@prudentialfirstchoice.com
engine is in central PA and you can hear the motor start and drive.
92projectcamaro
Jan 18, 2016 08:00 AM
z28guy134
Sep 1, 2015 11:50 PM
gixxer92
Sep 1, 2015 04:32 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
