FS: converted LT1 intake for SBC/TPI
Selling a converted LT1 intake for a sbc, ported for a 58mm TB, along with mild portwork to the runners, bolt holes modified for standard style heads, inner two holes not modified, you either have to drill and tap your heads or you can get away without bolting the inner ones up. Reason for keeping the stock location of those bolt holes is that the pre-87 heads, the angle of the bolts make it unable to get a bolt in, its much easier to use the orig location. All you need is a remote thermostat housing and fuel rails.
$300
Tony
Krazedz@yahoo.com
Located in NJ 08721
$300
Tony
Krazedz@yahoo.com
Located in NJ 08721
1992 Trans Am
May 10, 2023 07:19 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
