Selling a 350ci late model hyd roller short block, motor is all cleaned up and assembled with new main and rod bearings, rods and crank are stock with Mahl hyper pistons, flat tops.
$275
Tony
Located in NJ 08721
$275
Tony
Located in NJ 08721
pm sent
Hey Tony, I don't know if you got my PM, I sent it too you when you posted this on the other thread. I'm assuming this is the same one. Anyways I was wondering if you knew if this was internal or externally balanced also how many miles were on the stock crank/rods or if the crank was machined before rebuild. I dont mind driving to you unless you would consider shipping in which case would be great(of course I would pay for it and I already have cylinder heads so a short block is perfect). Also do you know what year the block is? Well if its a factory roller and 1 pc rear main seal, I can figure it out, unless it was retro lifters. Let me know, thanks.
-Russ
-Russ
Russ,
Yes this is the same, just decided to sell the parts seperate.
Its a stock bore, everything is standard, as for miles, not sure, i cleaned the bare block, light hone, cleaned and reassembled. has a high vol oil pump, 2 bolt main, its a internal bal setup, block is a late model roller block but not sure what year.
How much shipped to K7R3L1 Ontario, Canada? Also, can you post pics or send them to shift.2004@gmail.com ?
interested, located in north jersey, pickup can be arranged; if other sales fall through. Thanks
Do you have the casting numbers?
still for sale, heads are still attached, ported fuelies that i have listed here also, will sell as a long block for $500 or $275 as mentioned up above. Great motor for someone on a budget.
Tony
Tony
pic with the heads still on
only if you lived in the texas area
