FS: 82 - 92 3.73 gears and other parts
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
OEM GM 3.73 diff gears to fit Saginaw 10 bolt. Very good condition. Bought used from IWE as a spare set. Never used them. $150. O.B.O.
Holley 4150 750 DP main body. Milled air horn. $40
23mm rear sway bar. These are getting hard to find. $70
21 mm adjustable rear sway bar. $75
Front spindles. Need to mock up a big brake pkg? You need spare spindles. $25 each or the pair for $45
10.5" front rotors with 3" GM factory HP studs. Very good condition. $50
PM me or call me at: 778 836-8396
Local pickup only. Located in Metro Vancouver, BC area
Richard
Richard
Car: 86\92 Mutant
Engine: 355CI 430HP
Re: FS: 82 - 92 3.73 gears and other parts
Note: I can ship gears and Holley mainbody to USA if needed. Buyer to pay shipping. TIA.
Car: 86\92 Mutant
Engine: 355CI 430HP
New Lower Prices!!
Factory GM 3.73 diff gears to fit Saginaw 10 bolt. Very good condition. Bought used from IWE as a spare set. Never used them. $100..
Holley 4150 750 DP main body. Milled air horn. $25
23mm rear sway bar. These are getting hard to find. $60
21 mm adjustable rear sway bar. $65
Front spindles. Need to mock up a big brake pkg? You need spare spindles. $25 each or the pair for $40
10.5" front rotors with 3" GM factory HP studs. Very good condition. $40
PM me
Local pickup preferred. Located in Metro Vancouver, BC area
Richard
__________________
Hunter Motorsport Team Member.
New 2005 Knox Mountain Hill record.
1.58.636
Ioco hill record holder.
Lap Record SP3 Rivers Edge Raceway
2000 BC Autocross ESP Champion
1986 BC AutoCross ESP Champion
Car is SOLD
PM me
Richard
__________________
1.58.636
Car is SOLD
Car: 86\92 Mutant
Engine: 355CI 430HP
Car: 86\92 Mutant
Engine: 355CI 430HP
I received your reply. Everything sounds good. I sent you an e-mail back and sent you another PM also. Just let me know on the shipping on the gears to jacksonville, Florida 32223 if you will.
Thanks,
Chris
Thanks,
Chris
hectre13
Dec 11, 2023 08:14 AM
