msd 6al, Taylor wires, energy suspension, and more
Car: 86 z28, 87 IROC, 88 sc, 93 z28
Engine: LG4, LB9, LO3, LT1
Transmission: 700r4, T5, 700r4, 4L60
Axle/Gears: 3.73, 3.45, 2.73, 3.42
used msd 6al box. The tach feed does not work. I would like to get $100. $110 with 51, 53, 55, and 57 pills.
04-74211 Taylor Spiro-Pro 8mm Spark Plug Wire Set, 1988-1992 305/350 and 1987 305 F-body, Red Brand new, $35
energy suspension poly bushings for panhard and lcas. $20
Small cap distributor from 87 tpi with an almost new hypertech cap and rotor $40
tpi air box with bottom section cut $25
'70s 350 4 bolt block has been hot tanked and checked for cracks. It checked okay and is ready to be bored. It is currently at stock bore. This work alone was $110. I will sell with a 10/10 crank for $150
All prices plus shipping. Thanks.
Car: 92 RS
Engine: 396 sbc
Transmission: t5
Re: msd 6al, Taylor wires, energy suspension, and more
least you will take for the msd box? How much is it to send to MSD for repair if you know
I am firm at 100 or 110 with pills. This is just one way to feed a tach so I was never worried about fixing it. Other than the tach feed, it works fine.
Car: 1992 25th Anniversary White W/ Red
Engine: Procharged 383CI/ Soon LS2 Turbo
Transmission: Manual 700R4
Axle/Gears: 4:11/Auburn Posi/Moser Axle
40 shipped on the wires?
where are you located 92krvz28
I could take some tomorrow. PM me your email address and I will send them tomorrow evening.
Car: 83 camaro, 91 rs convertible
Engine: 94 LT1, 355 tpi
Transmission: 4L60, 700r4
Axle/Gears: 373 posi
what comes with the tpi air box? Any pics? shipping to 77080
I was just including the tpi lid and the lower section that holds the filters in place.
give me your email if you would like pics
tartagliaz28
Aug 15, 2015 10:59 AM
