PARTING OUT STREET/STRIP MOTOR AND ALOT OF OTHER PARTS
Old Dec 9, 2007 | 01:33 AM
scaryjerry's Avatar
Transmission: t-5
All parts DO NOT include shipping! I will ship everything but be papered to pay the shipping fees, it will be whatever ups charges, and I won’t cheat anyone one shipping charges. Local pick up is welcomed also. I live in Delavan Wisconsin.
On the 400 blocks I was told the 2 bolt mains are stronger than the 4 bolt ones because the center bolts go into the water jackets of the number 3 cylinder and I heard they crack easier.
1.)400 short block with stock crank and rods. 2 bolt mains. Speedpro forged pistons, stock bore. Less than 10k miles. High volume oil pump with a chrome oil pan. Also comes with a scat damper. Asking $500
2.)Brodix 11x aluminum heads fully rebuilt by (Pakes, I do have all the paper work and ill send it with the heads.) Brodix guide plates. They where milled .05, pressured checked, vacuumed checked, new guides and seals, and every valve was checked. 7/16 Arp studes. This also includes a matching solid roller comp cam(i have the comp card with all the spects but im selling it as a kit because it is a custum grind for these heads! It is ment for supercharger or nos), solid crower retrofit roller lifters, and summit racing 1.6 full roller rockers with locking bolts and harden pushrods. comes with a brass distributor gear aslo. Less than 1000 miles!! Asking $2000
3.)SOLD!!Holley stealth ram. Part number from summit is hly-7540 with fuel rails part number hly-534-185. My dad started to hand polishes the top plenum and fuel rails. It also comes with the water neck. Less than 1000 miles on I Asking $ 425.00
4.)SOLD!!!8 ford 30lbs injectors less than 1000 miles on them! Asking $125.00
5.)Stock throttle body for a tpi engine 48mm asking $ 25.00
6.)Hooker super comp long tube headers Part number from summit is hok-2210 with header wrap, one small dent on the bottom of the driver’s side. My dad fixes band instruments and be believes he can remove the dent. Less than 1000 miles on them! No rust! They are less than a year old. Asking $425.00
7.)400 short block. 509 block. 2 bolt main. This was from AutoZone with less than 5000 miles on it. The damper kept walking off and then I notice that the key and threads were beat up. I would put a new crank in it, but you could drill and tap new threads and tack weld the key in and you would be ok. This block is .40 over stock. I don’t know what kind of pistons it has but they are flat tops. This also has a high volume oil pump and a steal oil pan that has a hole drilled on the side due to a vortec supercharger return line. Asking $300.00
8.)eagle 383 stroker steal crank with 5.7 eagle I beam rods with 7 Keith black hypereutectic pistons .30 over stock. One piston cracked. Everything is in good shape and was balanced and blueprinted. One new piston and get it weight to match the other ones you could have a nice set up again.
Asking $350.00
9.)Hooker super comp shorties with a custom y pipe that fits very nice and tucks up for good ground clearance.1 3/4 pipes with 3inch collectors. Summit part number is hok-2460hkr Less than 5000 on them, no rust Asking $150.00
10.) Crane cams 3/8 locking stud bolts Brand new! still in the box! Asking $20.00
11.) T-5 bell housing with shifting fork. sbc fork,sbc
Asking $50.00
12.) T-5 tranny out of a 91 305 tpi firebird. World class! 26 spline. Comes with a B&M ripper short throw shifter and the bell housing with shifting fork. Very nice working order! Autozone clutch with less than 1000 miles on it.
Asking $500.00
13.Set of 4, 88 formula 350 rims. These were stripped and repainted and hand polished lip. Charcaol centers with polished lip. Very clean! No center caps though. Asking $400.00
14.) Slp cam it is the smaller one of the two they offer. Think it’s in the 480 lift and it is a direct replacement for a stock 305 or 350 tpi car. Asking $50.00
15.)Sbc chrome valve covers. Tall set made by edelbock with a dent on one of them. (Still works fine, I'm using them right now). Part number from summit is edl-4649 perimeter bolt pattern Asking $20.00
16.) Sbc chrome valve covers. Short style with the symbol of a bowtie and Chevrolet. Part number from summit is pro-141-102 perimeter bolt pattern Asking 20.00
17.) Msd blaster coil. Asking $ 20.00
18. flywheel. 153 tooth for a two peace rear main. Asking $ 30.00
19. 400 balance plate Asking $ 5.00
20. I do have 3 other flywheels that im not sure what they are off hand but just ask if your looking fro something specific.
21.) 88 firebird serpentine set up with water pump. It doesnt come with a ac conpresser or power stering pump. Asking $75
22.)Ac delete box. One of the bolt holes i had to use a torch on because it was just spinning but still in good shape. Asking $ 100
21. I have some extra t-5 parts, cases, tail shafts, some gears, just ask.
Only reason I’m Parting everything out is that I’m going to a big block. I am open for trades that will help me with putting a big block and an lt1 t-56 into my thirdgen firebird. I’m also looking for a built rear-end, K-member with an arms, slicks and skinny’s, suspension parts. I’m not sure which way I’m going with this motor so nos, turbo, supercharger. So far i have a vortec 454 out of 99 1ton truck with a rod knock.
I can send pics and if you have any questions I will try to answer them as fast as I can. Please feel free to call and or email me to scaryjerry912@yahoo.com. My phone number is 262 745 2432 and my name is jerry.
Last edited by scaryjerry; Dec 10, 2007 at 11:08 PM. Reason: adding some new parts
Old Dec 9, 2007 | 01:39 AM
scaryjerry's Avatar
Transmission: t-5
Re: PARTING OUT STREET/STRIP MOTOR AND ALOT OF OTHER PARTS
Also i have a msd inline fuel pump good up to 125lbs asking $50.00
ac delete pully asking $40.00
i can accept paypal or money order.
Old Dec 9, 2007 | 01:47 AM
scaryjerry's Avatar
Transmission: t-5
also have a set of summit lightweight horsepower 3/8 1.6 roller rockers. part number sum-g6920b with locking bolts. Less than 5k on them.
asking 75.00
keep forgetting all the parts i have and my main page wont let me edit it to add.
Old Dec 9, 2007 | 12:36 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Would like to see pics of stealth ram and rails.
Old Dec 9, 2007 | 02:25 PM
scaryjerry's Avatar
Transmission: t-5
http://i120.photobucket.com/albums/o...l/DSCF3141.jpg
RIMS
http://i120.photobucket.com/albums/o...l/DSCF3146.jpg
30LBS INJECTORS
http://i120.photobucket.com/albums/o...l/DSCF3145.jpg
hOLLEY STEALTH RAM
http://i120.photobucket.com/albums/o...l/DSCF3142.jpg
HOLLEY STEALTH RAM
http://i120.photobucket.com/albums/o...l/DSCF3143.jpg
HOLLEY STEALTH RAM
http://i120.photobucket.com/albums/o...l/DSCF3144.jpg
HOLLEY STEALTH RAM
Old Dec 9, 2007 | 03:40 PM
85SILVERBULLET1's Avatar
Car: 85 Trans Am
Engine: 383 ci
Transmission: Liberty Geared Tko 600
Axle/Gears: Moser 9" 4.11 gear wavetrac locker
check pm...
Old Dec 9, 2007 | 04:36 PM
raven0840's Avatar
Car: '83 Camaro Z-28
Engine: 350 Crossfire
Axle/Gears: 3.23 posi
PM sent
Old Dec 9, 2007 | 09:11 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
PM sent about cam.
Old Dec 10, 2007 | 06:58 PM
scaryjerry's Avatar
Transmission: t-5
http://i120.photobucket.com/albums/o...l/DSCF3161.jpg
BOWTIE VALVE COVERS
http://i120.photobucket.com/albums/o...l/DSCF3160.jpg
BOWTIE VALVE COVERS
http://i120.photobucket.com/albums/o...l/DSCF3159.jpg
CRAN CAMS LOCKING NUTS
http://i120.photobucket.com/albums/o...l/DSCF3158.jpg
http://i120.photobucket.com/albums/o...l/DSCF3157.jpg
http://i120.photobucket.com/albums/o...l/DSCF3155.jpg
MSD COIL
http://i120.photobucket.com/albums/o...l/DSCF3154.jpg
MSD COIL
http://i120.photobucket.com/albums/o...l/DSCF3152.jpg
HOOKER SHORTIES
http://i120.photobucket.com/albums/o...l/DSCF3151.jpg
HOOKER SHORTIES
http://i120.photobucket.com/albums/o...l/DSCF3150.jpg
HOOKER SHORTIES
http://i120.photobucket.com/albums/o...l/DSCF3147.jpg
SBC BELLHOUSING
http://i120.photobucket.com/albums/o...l/DSCF3162.jpg
30LBS INJECTORS
http://i120.photobucket.com/albums/o...l/DSCF3163.jpg
these are the 3/8stud 1.6
http://i120.photobucket.com/albums/o...l/DSCF3166.jpg
a/c delete box
Old Dec 11, 2007 | 10:53 AM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
ill buy the block if you send me a pic
Old Dec 11, 2007 | 03:58 PM
maroman88's Avatar
Car: 88 Camaro Coupe - 99 Corvette
Engine: 305TPI - LS1
Transmission: A4 - A4
Axle/Gears: 3:73 - 3:15
PM sent
Old Dec 11, 2007 | 09:36 PM
scaryjerry's Avatar
Transmission: t-5
what block are we talking about? the one with forged pistons is 511
and the one that is .40 over is the 509
Old Dec 11, 2007 | 10:30 PM
scaryjerry's Avatar
Transmission: t-5
6.)Hooker super comp long tube headers Part number from summit is hok-2210 with header wrap, one small dent on the bottom of the driver’s side. My dad fixes band instruments and be believes he can remove the dent. Less than 1000 miles on them! No rust! They are less than a year old. Asking $425.00 just for the headers. also i have a custom y pipe that has flanges on both sides for easy removel and a custom tranny mount that allows the exhaust to sit up real close to the floorboards for good ground clearence aslo with copper gaskets. Asking 650 for everything!
Asking $350.00
9.)SOLD......Hooker super comp shorties with a custom y pipe that fits very nice and tucks up for good ground clearance.1 3/4 pipes with 3inch collectors. Summit part number is hok-2460hkr Less than 5000 on them, no rust Asking $150.00
Asking $50.00
Asking $500.00
22.) MSD inline fuel pump. good up to 125lbs Asking$50
23.) a/c delete pulley asking $40
24.) stock tpi distributor with a brand new stator. no gear. asking 25.
25.) SOLD... 1.6 3/8 stud roller rockers.
Old Dec 11, 2007 | 10:35 PM
karrfirebird87's Avatar
Engine: 350 4 boltmain goodwrench crate
Transmission: 350 turbo 3 speed
Axle/Gears: i belive its a 323 gear ratio posi
GOT ANY BETTER PICS OF ROLLER ROCKERS IF YOU DO PLEASE SEND THEM TO KINGIN1211@YAHOO.COM THANKS</p> AN WHAT ARE THEY OFF OF
I ALSO HAVE SOME PERFORMANCE REWORKT HEADS OFF A 70 SOMETHING CHEVY 454 IF YOUR INTERESTED
Old Dec 11, 2007 | 11:35 PM
scaryjerry's Avatar
Transmission: t-5
http://i120.photobucket.com/albums/o...l/DSCF3178.jpg
SIDE OF THE T-5
http://i120.photobucket.com/albums/o...l/DSCF3174.jpg
T-5
http://i120.photobucket.com/albums/o...l/DSCF3173.jpg
B&M RIPPER SHIFTER
http://i120.photobucket.com/albums/o...l/DSCF3172.jpg
BELLHOUSING THAT COMES WITH THE T-5
http://i120.photobucket.com/albums/o...l/DSCF3185.jpg
CLUTCH ITS SO NEW YOU CAN STILL READ FLYWHEEL SIDE
http://i120.photobucket.com/albums/o...l/DSCF3182.jpg
INPUT SHAFT 26 SPLINE
http://i120.photobucket.com/albums/o...l/DSCF3186.jpg
EVERYTHING YOU GET WITH THE T-5 SET UP FOR $500
http://i120.photobucket.com/albums/o...l/DSCF3196.jpg
EVERYTHING YOU WOULD GET WITH THE LONG TUBE HEADERS CUSTOM Y PIPE AND CUSTOM TRANNY MOUNT
http://i120.photobucket.com/albums/o...l/DSCF3195.jpg
THE Y PIPE AND TRANNY MOUNT
http://i120.photobucket.com/albums/o...l/DSCF3194.jpg
Y PIPE
http://i120.photobucket.com/albums/o...l/DSCF3193.jpg
CUSTOM TRANNY MOUNT
http://i120.photobucket.com/albums/o...l/DSCF3192.jpg
CUSTOM TRANNY MOUNT
http://i120.photobucket.com/albums/o...l/DSCF3191.jpg
INSIDE OF THE LONG TUBE TO SHOW NO RUST!
http://i120.photobucket.com/albums/o...l/DSCF3190.jpg
PASSANGER SIDE HEADER, LONG TUBE
http://i120.photobucket.com/albums/o...l/DSCF3189.jpg
DRIVER SIDE HEADER, LONG TUBE
http://i120.photobucket.com/albums/o...l/DSCF3188.jpg
BOTH LONG TUBES WITH COPPER GASKETS
http://i120.photobucket.com/albums/o...l/DSCF3187.jpg
THE SMALL DENT ON THE BOTTOM OF THE DRIVER SIDE HEADER
http://i120.photobucket.com/albums/o...l/DSCF2875.jpg
HOW THE LONG TUBES FIT ON MY CAR
http://i120.photobucket.com/albums/o...l/DSCF2873.jpg
GROUND CLEARENCE OF THE LONG TUBES ON MY CAR
http://i120.photobucket.com/albums/o...l/DSCF2883.jpg
LONG TUBES ON MY CAR GOOD PIC OF THE Y PIPE
http://i120.photobucket.com/albums/o...l/DSCF3184.jpg
THE 400 BALLANCE PLATE
http://i120.photobucket.com/albums/o...l/DSCF3183.jpg
153 TOOTH 2 PIECE REARMAIN.
http://i120.photobucket.com/albums/o...l/DSCF3199.jpg
SERPENTINE BRACKETS, WITH THE A/C DELETE PULLEY
http://i120.photobucket.com/albums/o...l/DSCF3198.jpg
A/C DELETE PULLEY ON BRACKET
http://i120.photobucket.com/albums/o...l/DSCF3171.jpg
ALTERNATOR SIDE BRACKET.
http://i120.photobucket.com/albums/o...l/DSCF3164.jpg
SLP CAM
http://i120.photobucket.com/albums/o...l/DSCF3167.jpg
SLP CAM SPECS
Old Dec 12, 2007 | 01:51 PM
ssj2link's Avatar
Car: 2000 Trans am vert 87 GTA
Engine: 5.7/5.0
Transmission: T56/700R4
u got a PM
Old Dec 13, 2007 | 09:35 PM
scaryjerry's Avatar
Transmission: t-5
bump
Old Dec 23, 2007 | 02:58 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Do you any pics of the first 400 sb. Also what are the cam specs, compression ration, etc.
Old Dec 23, 2007 | 05:46 PM
bonesbrakr's Avatar
Picture of the throttle body please and does it come with the IAC and TPS ....
Bill
Old Dec 24, 2007 | 03:19 PM
scaryjerry's Avatar
Transmission: t-5
5.)SOLD!!!Stock throttle body for a tpi engine 48mm asking $ 25.00
6.)Hooker super comp long tube headers Part number from summit is hok-2210 , one small dent on the bottom of the driver’s side. My dad fixes band instruments and be believes he can remove the dent. Less than 1000 miles on them! No rust! They are less than a year old. Asking $425.00 just for the headers. also i have a custom y pipe that has flanges on both sides for easy removel and a custom tranny mount that allows the exhaust to sit up real close to the floorboards for good ground clearence aslo with copper gaskets. Asking 650 for everything! HAVE NEW PICS, ASK
Asking $350.00
Asking $50.00
Asking $500.00
14.) SOLD!!Slp cam it is the smaller one of the two they offer. Think it’s in the 480 lift and it is a direct replacement for a stock 305 or 350 tpi car. Asking $50.00
19. SOLD!!400 balance plate Asking $ 5.00
21.) SOLD!!!88 firebird serpentine set up with water pump. It doesnt come with a ac conpresser or power stering pump. Asking $75
26.) a autozone gold starter for a 305. less than a month old. asking 35.
Old Dec 25, 2007 | 08:23 PM
scaryjerry's Avatar
Transmission: t-5
NEW PICS OF THE HOOKER SUPERCOMP HEADERS 2210.
http://i120.photobucket.com/albums/o...l/DSCF3247.jpg
http://i120.photobucket.com/albums/o...l/DSCF3246.jpg
http://i120.photobucket.com/albums/o...l/DSCF3245.jpg
http://i120.photobucket.com/albums/o...l/DSCF3244.jpg
http://i120.photobucket.com/albums/o...l/DSCF3243.jpg
http://i120.photobucket.com/albums/o...l/DSCF3242.jpg
BRODIX 11X HEADS, CAM, ROLLER LIFTERS, ROLLER ROCKERS, PUSHRODS.
CAM
http://i120.photobucket.com/albums/o...l/DSCF3239.jpg
CAM
http://i120.photobucket.com/albums/o...l/DSCF3238.jpg
EVERYTHING YOU GET
http://i120.photobucket.com/albums/o...l/DSCF3234.jpg
ROLLER ROCKERS
http://i120.photobucket.com/albums/o...l/DSCF3233.jpg
ROLLER ROCKERS
http://i120.photobucket.com/albums/o...l/DSCF3232.jpg
CROWER ROLLER LIFTER
http://i120.photobucket.com/albums/o...l/DSCF3229.jpg
ROLLER ROCKRS, ROLLER LIFTERS, PUSHRODS, AND LOCKING NUTS
http://i120.photobucket.com/albums/o...l/DSCF3227.jpg
iNTAKE RUNNERS, WITH SLIGHT PORTING
http://i120.photobucket.com/albums/o...l/DSCF3224.jpg
INTAKE SIDE OF HEAD
http://i120.photobucket.com/albums/o...l/DSCF3223.jpg
EXAHUST SIDE STANDARD PORT
http://i120.photobucket.com/albums/o...l/DSCF3220.jpg
TOP VIEW
http://i120.photobucket.com/albums/o...l/DSCF3222.jpg
VALVES, 2.08 AND 1.60
http://i120.photobucket.com/albums/o...l/DSCF3219.jpg
BOTTOM OF HEAD, ALSO HAS 400 STEEM HOLES
http://i120.photobucket.com/albums/o...l/DSCF3218.jpg
BRODIX 11X
http://i120.photobucket.com/albums/o...l/DSCF3215.jpg
SIDE
http://i120.photobucket.com/albums/o...l/DSCF3217.jpg
CASTING NUMBERS
http://i120.photobucket.com/albums/o...l/DSCF3213.jpg
CASTING NUMBERS
http://i120.photobucket.com/albums/o...l/DSCF3212.jpg
Old Dec 28, 2007 | 06:40 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Bought serpentine setup from jerry. Prompt shipping on items. One part was damaged and he gladly refunded part of the cost. Highly Reccommend. Badman
Old Dec 28, 2007 | 07:32 PM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Engine: 305 TBI (L03)
Transmission: 700R4 w/ Corvette servo
Axle/Gears: 4th Gen, 3.23, posi, PBR
PM sent on MSD coil
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
fonzie85
Aug 13, 2015 11:50 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
1nastygta
Aug 8, 2015 07:38 PM
