engine components
Old Dec 30, 2007 | 07:24 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
engine components
I have a rotating assembly out of a 400 sbc. Stock rods and crank with 30 over hyperutetic aluminum pistons. Along with a set of heads from a 305 TPI. The crank is in good shape could use a polishing but no nicks that your thumb nail catches when you drag it accross the journal. I just have no use for the rotating assembly because i want to be able to spray the motor i'm building so i went with a scat rotating assembly. The heads were for a rebuild i started 2 years ago and never did anything with. The heads have been cleaned and the valves and springs were checked and still good they're all clean and sitting in a box. I also have other stuff like an axle from a 98 Z28, misc engine mounts, random parts from 2 parts cars and several scavenging missions in the local salvage yards
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
NinjaNife
Aug 23, 2015 11:49 AM
Winchester1094
Aug 18, 2015 10:23 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
