Garage cleanup!!!!
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Garage cleanup!!!!
I have (1) R.J.S. Red 5 pt. harness for sale. Date stamp is April 2006. $30
Drivers window regulator and motor. $25
Passenger window regulator and motor. $25
Holley Fuel Pressure Regulator 12-803. $10
Billet Y-Block 3/8 inlet & outlets with pressure port. $10
416 Heads $50
(6) KB pistons .030 305 p/n KB144 $100
Stock front springs 1984 Z28 $40
Hood w/ VFN 6" Scoop (on car in pic), not show quality $75
Radiator from 1984 Z28 (no trans cooler) $40
28x9 MT Slicks (have alot of passes on them, but still work good) $50
Cleaning up garage more to add later!!
416 Heads $50
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
Re: Garage cleanup!!!!
Heads are good, removed from a running 305, no cracks, shipping, I'm not sure on but probably at least dbl what the price of the heads are. UPS charged 15.00 to ship out a 5pt. harness that weighed 6 lbs
I will check and let you know though.
I will check and let you know though. Thread Starter
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
UPS is outrageous....however looking on fed-ex site looks like I could ship for approximately $65.00. So grand total of $115.00.
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
86FIREBIRDSBC: I'm sure the hood would be atleast $150.00 to ship but will check further if you are interested.
creepingdeath: Will have to check, not sure how bad shipping would be to canada guessing somewhere around $40, just let me know.
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
Re: Garage cleanup!!!! UPDATED
I have (1) R.J.S. Red 5 pt. harness for sale. Date stamp is April 2006. $30 SOLD
Holley Fuel Pressure Regulator 12-803. $10 Pending
Billet Y-Block 3/8 inlet & outlets with pressure port. $10 Pending
416 Heads $50
Radio Trim Bezel $10
416 Heads $50
Car: 1983 Camaro Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: Strange S60
would it be possible to just get one of the heads? all I need is one of them and that would cut shipping down some... those are the 1.84 intake valves right?
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
Would prefer not to split up the heads, but I could do it for $70 shipped.
416 Heads $50
Torque arm mount for TH400 with Poly bushing $50
Stock Torque Arm $15
Weiand 7546 Intake $65
Holley 650 DP with milled off choke horn $250
416 Heads $50
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
Holley Fuel Pressure Regulator 12-803. $10 pending
Billet Y-Block 3/8 inlet & outlets with pressure port. SOLD
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
Hood w/ VFN 6" Scoop (on car in pic), not show quality $75 SOLD
Car: 1987 IROCZ
Engine: 355, Vortec Heads, Carbed
Transmission: TH350, 2800 stall
Axle/Gears: 3.27 9 Bolt
How much for the slicks shipped to 23072? Will the clear the stock wheel well?
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
Slicks will clear stock wheel wells.....I will check on shipping
Springs had some surface rust on them, when I took them out I cleaned them up and gave them a fresh coat of black paint.
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Still have this...
I want it...you take paypal?
Shipping will be to ramsey, nj 07446
Linson
Oct 1, 2015 09:50 PM
