posi disc rear end
Car: 1985 Z-28
Engine: 350 4bbl
Transmission: t-5
Axle/Gears: 4.11
posi disc rear end
Hey guys I have a posi disc brake rear end for sale if memory serves me correct its got 373 gears but dont hold me to it its still in the car and comes with the rotors pads everything so you can just drop it in your car.. im looking to get 200 for it pick up in cocoa Fl
Re: posi disc rear end
does the posi and every thing still good in it and are u shure it has alll the parts for it?? last one i brought from you had no backing plates or rear calibers the ones it came with where front calibers.but i need another rearend. what other parts do u have??
Car: 1985 Z-28
Engine: 350 4bbl
Transmission: t-5
Axle/Gears: 4.11
the rear end sit in the car as i speak im parting the car out and its all hooked up in that car.. if someone want the rear im just gonn cut it out rear quicand drop it you can pull everything you think you need with it brake lines whatever idk.. I have almost a whole 83 camaro im parting out. the only thing im not sure of is the gearing its 373 or 342
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
to find out the ratio mark drive shaft and see how many rotations with one spin of wheel
hectre13
Dec 11, 2023 08:14 AM
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
