2.8 700r4 radiator and various 2.8 parts
i bought a 85 firebird with a 2.8, did a general tune up on it to see if would work alright, and the car idled good w/ new spark plugs, wires, ram air intake. it had no tags on it so i couldnt drive it far, it shifted good into reverse and drive, etc when sitting. i drove it up my street with my tags on it, and it seemed to not have much power, even for a 2.8, so i did a compression check and it has a blown head gasket. my decision is to swap a v8, so everythings gotta go.
block, heads, intake manifolds, w/new manifold and head gaskets installed, and new bolts for the plenum to lower intake manif., new plugs wires, distributor, fuel rail, injectors, throttle body w/TPS and IAC and new heater hoses for the TB. stock exhaust manifold included, with egr valve, new pcv valve and all new vacuum lines and vacuum routing sticker. also comes with p/s pump, water pump and alternator plus pulleys and belts. only thing missing is the FPR cus i was trying to see if i could make it adjustable and i couldnt. theyre around 65 or 70 for a new one. i would like $300 obo for everything just listed, and i would prefer to sell it as a whole. plus the engine is still in the car so i have to pull it if i get a serious buyer. for another $80 ill include the air intake w/ brand new AEM cone filter and MAF and AIT
the transmission, like i said shifted fine into reverse and drive, did a fluid and filter change on it, and lost two or three of the pan bolts, shouldnt be hard to match at the hardware store though. $150 obo
various stock suspension parts, sway bars, springs, panhard rod, torque arm, control arms, front a arms, all going. check with me i only keep them for a week or two then i take em to the dump.
also have a radiator for a 2.8, w/ inlet hose on pass side and outlet on drivers side w/trans cooler lines, new rad cap and new top hose. radiator was brand new only installed for a couple weeks while the car sat, and it worked great. look up p/n P919 on www.autopartswarehouse.com im 99% sure its the same one i got from pep boys. would like $80 obo w/cap and hose
i have some other random parts just ask i cant rmember everything. i am located in maryland, just outside wash dc. thanks for reading.
Car: 83 firebird under construction
Engine: V6
Transmission: not sure
Axle/Gears: not sure
Re: 2.8 700r4 radiator and various 2.8 parts
what i really need are the alternator and pwr steering pump, however if you can flex on price i'd be interested in everything (always good to have xtra parts ya know) i'd need it shipped though quote me a price w/ shipping to 28306 and we'll go from there ok
thanks
steve
thanks
steve
bump $200 for engine and everything attached to it, $100 for trans, $50 for radiator. still have lots of stock suspension parts, stock k member etc.
pulled out all the wiring today, anybody needs wiring, computer, relays, specific connectors etc let me know... everything is still available, ill part it all out...
LT1Formula
20
Nov 14, 2015 12:02 AM
