MSD HEI Parts, and timing controller
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
slightly used (1500 miles) MSD Ignition 8680 timing control *** w/ MSD 8860 Mag pick up harness extention, $95 shipped
http://store.summitracing.com/partde...5&autoview=sku
One wire has been cut on the module for it to run on a V-6, this can be soldered to have it operate on a V-8 again.
MSD 83645 HEI module, this was used for about 8,000 miles works great, and so does the Rev limiter, I switched to a Mallory hyfire box. This will only come with the module and the longer screws. I recomend going to a computer store, or radio shack and get some thermal paste for the heat plate. $50 shipped
I do have a used distributer base, and could build a whole distributer, with a new magnetic pick up installed, a MRgasket mech advnace kit, and MRgasket vacuum advance canister that i could install the MSD module, set at what ever rev limit you want, and a new MSD Cap/Rotor and new stock replacement HEI coil. I can do $120 shipped if I build it, $100 shipped if you build it with these included parts
Car: 87 Firebird
Engine: 5.3 76mm
Re: MSD HEI Parts, and timing controller
TTT need gone.
$200 shipped, and I will build the distributor, and send the ignition retard box.
Car: 87 Firebird
Engine: 5.3 76mm
ttt, Im open to offers/different combinations of what you want thats listed.
Car: 87 Firebird
Engine: 5.3 76mm
Offers? I need gone.
9192camaro
16
Feb 3, 2019 12:21 AM
