Converted LT1 Intake 4 TPI 4 Sale
I have here 18 1994 - 1997 and 2 1993 LT1 Intakes modified to replace the TPI intake. This upgrade is cheaper then buying upgrades for the TPI. The LT1 has a RPM range from Idle to 6000 RPM, unlike the TPI which levels off at 4800 RPM, (even after upgrades). There is a list of helpful sites on the bottom of this thread.
I’m offering each intake for $440.00 plus shipping (do to the rising costs and the high cost of the remote thermostats, I had to increase the price by $40). Here is a list of what comes with it.
(A)Pre 1986 intake http://i280.photobucket.com/albums/k...fdb44377-1.jpg
(B)Post 1987 intake
(C)Intake core for JUST an intake and remote thermostat -$110
(D)Intake core for JUST an intake, remote thermostat and throttle bracket -$100
(E)Bore the throttle bores to 60mm http://i280.photobucket.com/albums/k...f84a4ad4a2.jpg
(F)Bore air gap http://i280.photobucket.com/albums/k...9f57162106.jpg
(G)No epoxy fill for exhaust cross over ports -$5 http://i280.photobucket.com/albums/k...703a76d8fb.jpg
(H)Plug up MAP hole
(I)Convert fuel rails to AN-6 series +$30
(J)Convert fuel rails to AN-8 series +$30
(K)Convert fuel rails to AN-6 Parallel +$40
(L)Convert fuel rails to AN-8 Parallel +$40
(M) Convert fuel rails to AN-6 on back and AN-8 front Parallel +$40
With the fuel rails you must specify what position you want the fittings to be in the front.
(M)I have 2 1993 intakes, so for those guys that want the parallel AN fittings fuel rails, I hope you don’t mind that I give you these intakes. I can tell you that the 1993 fuel rails are a thicker casting then the post 1994 fuel rails http://i280.photobucket.com/albums/k...c69a4c3a97.jpg
For the intake core, if you send me a 1993 intake then I will send you back a modded 1993 intake, if I run out I will send you back your 1993 intake. They are great intakes but for some reason GM used a harder aluminum and that makes them hard to work on. They are also not that versatile to sell unlike its 1994 – 1997 counter parts.
This is a first come first serve basis after payment. It could take 2 weeks or more after payment depending on modifications added.
If you have any questions my cell is 410 322 4580 if I don’t answer please leave a message or email aholzhaus69@hotmail.com subject “lt1 intake”. I will accept money order, personal check (I wont ship until the check clears) or paypal with 3% fee ( I charge a 3% paypal fee, because my prices are low already, that I can’t afford to give paypal any of it.)
I will not modify your intake, because I do these in batches and it would take to long to mod individual intakes. I do not guarantee any rubber seals or the original pressure regulator. I do guarantee my craftsmanship, so if you have a problem, please contact me first so we can fix the problem, if its to bad I will give you a refund (after I get it back) plus the cost of the shipping to you.
lt1inake.com
http://www.popularhotrodding.com/tec...ls1/index.html
http://www.gmhightechperformance.com...use/index.html
SORRY EVERYONE. Because of the economy, the cost and labor involved with modifing these intakes. I completely liquidated my inventory.
SORRY
http://s280.photobucket.com/albums/k..._tab_my_albums
- Modified intake
- Fuel rails with retaining clips and blots
- Rear ¾ coolant nipples
- Remote thermostat
- Modified 1993 Throttle bracket with bolts
- Windage tray with bolts
- MAP bolts or MAP hole sealed
- sandblasted http://i280.photobucket.com/albums/k...55a8641eb4.jpg
OPTIONS
(B)Post 1987 intake
(H)Plug up MAP hole
Helpful sites
lt1inake.com
SORRY
Re: Converted LT1 Intake 4 TPI 4 Sale
I’m offering each intake for $400.00 plus shipping.
(B)Post 1987 intake
(H)Plug up MAP hole
lt1inake.com
- Modified intake
- Remote thermostat
OPTIONS
(B)Post 1987 intake
(H)Plug up MAP hole
Helpful sites
lt1inake.com
Depends, do you want the rear EGR casting Removed? If not what other mods would you want, I offer a Air Gap (after the EGR catsing is removed) and I offer opening the Throttle Bores to 60 mm. Please email me
1992 Trans Am
May 10, 2023 07:19 PM
Sanjay
Aug 12, 2015 03:41 PM
