1986 TPI setup..Complete, wiring, ecm, sensors
Old Sep 14, 2008 | 10:02 PM
R3500's Avatar
This unit came off a 1986 IROC with automatic transmission. This was my personal TPI setup for my street rod that I never installed. I picked up a Speed Density package and don't want to break this set up. Selling this as a complete unit only.
Complete Tune Port Injection (TPI) system for a Chevy small block. Includes:
Intake manifold base (If you have the newer style heads I can supply a center bolt manifold instead)
Upper plenum
Runners
HEI Distributor
Throttle body
Fuel rail with 19lb injectors (all Ohm at 16)
ECM Computer 1227165 with correct prom inside “AUM”
4 Out buffer
Air Ducting with Mass Air Flow MAF sensor
Complete OEM wiring harness
All misc. sensors
$350 plus shipping..prefer local pick up.
NOTE: If interested please contact me via my e-mail: ziptow@yahoo.com
It is easier for me to communicate via e-mail and not this forum.
Here is a link for "many more pictures":
http://s15.photobucket.com/albums/a3...TPI/?start=all
Old Sep 16, 2008 | 06:58 PM
R3500's Avatar
Re: 1986 TPI setup..Complete, wiring, ecm, sensors
Pictures of the ECM, wiring etc are at the link noted above or here it is again:
Old Sep 19, 2008 | 07:32 PM
R3500's Avatar
ttt
Old Sep 20, 2008 | 07:43 PM
Dangerousdan's Avatar
Want a title? Post!
I'm interested in your TPI setup. I have a couple of questions.
Will this manifold bolt to the aftermarket early md. heads?
Is your dist. small or large cap?
Would you have the '89 manifold with tubes and plenum?
Thanks.
Old Sep 20, 2008 | 08:28 PM
tonythetoad's Avatar
Car: 91 convertible, 89 TTA, 03 GT2
Engine: 5.0 TBI, 3.8 Turbo, 3.6 Twin Turbo
Transmission: 700r4, 2004r, 6 Speed
Axle/Gears: 2.73, 3.27
I have seen this setup in person and it looks better than new.
TTT
Old Sep 20, 2008 | 08:41 PM
R3500's Avatar
DangerousDan
The large distributor (HEI) in the picture comes with it...and you have the choice of old or new style base intake...see pics.
I can set you up with a small distributor and external coil if needed, but the harness is for the large one.
TonytheToad..thanks for the bump.
Old Sep 20, 2008 | 09:47 PM
Want a title? Post!
I would like the unit if you seperate the ecm/ wiring. Also I would need a '89 base plate without the ninth injector in the base plate .
Old Sep 20, 2008 | 10:23 PM
R3500's Avatar
Thanks for the offer...but like I noted..being sold as a package.
RE: 89 base....you could just block off the 9th injector hole on the pre 89..I have the cold start block offs and blocked off runners.
But good luck finding what you need...I think member "baknblk" has a complete speed density setup for sale for about $500
Old Sep 21, 2008 | 09:26 AM
Want a title? Post!
Thanks, If your willing to work with me on the above items, what is your final
price?
Old Sep 23, 2008 | 07:58 PM
R3500's Avatar
TTT
Old Sep 28, 2008 | 07:44 PM
R3500's Avatar
Might be called for..but just in case:
Old Sep 29, 2008 | 07:21 PM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
By any chance do you still have the TPI set up for sell.
Is You do can you call me at 562-726-9814
Old Sep 29, 2008 | 08:49 PM
R3500's Avatar
saritasan
Sending you a PM
Caspar
Jun 19, 2016 11:19 PM
R3500
Aug 17, 2015 12:16 PM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
marcusaw
Aug 10, 2015 08:13 AM
