HO 305 heads and 373 gears and posi
Car: 1986 camaro
Engine: 406ci
Transmission: th400
Axle/Gears: 3.55
I have a set of heads with 10,000 miles on them. Theyare 305s high out put The cast # on the is 14102183 like to get $100.00 plus shipping. or make me an offer they have to go I also have a 28 spline posi with a 373 richmond gear I dont know much about the unit but the gears look great came from a 1998 camaro. I was going to put it in my third gen and beef up the axles from 26 to 28 splines makes a easy swap. asking $125.00 + shipping call matt for pictures at 240-298-6705
Car: 1989 firebird formula, 1991 z/28
Engine: none LSX! one day, 350tpi
Transmission: none t56 one day, t5
Axle/Gears: 9-bolt 3.45, 10 bolt 3.73
Re: HO 305 heads and 373 gears and posi
will you take 125 shipped for posi and gears
Car: 1986 camaro
Engine: 406ci
Transmission: th400
Axle/Gears: 3.55
bump
whats your zip code so i can see what the shipping will cost
I can get pictures of these heads tonight i can send them to you by pic. phone. or i can try to e-mail them to you. I just realized last night that the cast # i posted is not right
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Car: 1986 camaro
Engine: 406ci
Transmission: th400
Axle/Gears: 3.55
my email is joeblue83@yahoo.com pics of the heads
Car: 1986 camaro
Engine: 406ci
Transmission: th400
Axle/Gears: 3.55
so will you take 125 shipped for the gears and posi
Car: 1988 Camaro
Engine: 383 Stroker
just got them. Would they fit on a 86 camaro with a 305. Can I use the rest of the stock head parts with these, and what is the difference between the stock heads on right now and these h.o. heads. PM me with shipping to 53508
Car: 1986 camaro
Engine: 406ci
Transmission: th400
Axle/Gears: 3.55
from what i looked up the intake ports are bigger with a better flow pattern so the air and fuel ratio is more eff. as far as the rest of your parts. if your valve cover are center bolt holes every thing will bolt up if not You can modify your intake to fit. all you have to do here is the 2 bolt hole on the inside of the intake have a different pitch so you have to oval them. The others willscrew right in . the angle of the intake and heads is the same. all rockers and push rods will be the same. and valve covers if not center bolt holes. a junk yard will have them real cheep. shipping will be $37.67 a head so it will be $75.00 for the pair. UPS ground total shipped $175.00
Car: 1988 Camaro
Engine: 383 Stroker
I just checked and they are not center bolt. Damn! Looks like I am going to have to pass
Thanks Anyways
Thanks Anyways
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
