1985 Camaro Z-28 ZZ4 350 5spd posi selling as roller/part out
Old Oct 19, 2008 | 11:22 AM
dpmalibu's Avatar
Same car that I have been selling for a while now. There has been no serious interest as a turn key car so now I am going to sell it as a roller or part it out (somewhat). I am NOT going to strip this done to nothing because its too nice. Instead I will sell it as a roller either with no motor only but with everything else for $4000 B/O.
2) Roller w/o motor/trans (stick set up will not be included), possibly with cat back exhaust w/ stock rear , stock rear suspension, w/ 16" wheels ( no headers, Y-pipe, aluminum radiator, electric fan/controller, ignition box)
$2000 B/O
3) same as #3 but no cat back or 16" wheels $1200 B/O
4) Stick set up minus trans (includes almost brand new Hayes clutch (1800 miles), Hayes billet steel flywheels 153 tooth (500 miles)bellhousing,hurst shifter, clutch pedal and all clutch hydraulics $450 add $150 for rebuildable T-5.
5) ZZ4 350 just as you see it in pics with all the polished parts,brackets, new Holley 670 carb.otor was dyno tuned by local shop(have dyno sheet). Runs strong. No leaks, smoke $3500
6) rebuilt 10 bolt disc brake rear w/ new Auburn Pro posi unit, Precision Performance 3.73 ring/pinion, Moser axles, new bearings/seals, ARP 2.5" extended axles studs, MAC stud girdle cover, almost new brake pads, 1 new e-brake cable(other one is in good shape). Rear has 1800 miles. rear is basically bullet broof other than welding the axle tube which I was planning on doing but did get to do. $900
I will not pull parts off until I sell either body , motor or trans set up sells first. Once this stuff is gone I will then list individual parts. I want to give people a chance to test drive car/hear it run for the drivetrain parts.
Rolling body will come with the 4th gen interior ,aftermarket gauges ,etc.
I am located in Hatboro,PA. 10 minutes from Philly , 40 minutes from Trenton area. Pm me if interested . I want to try to sell at least the body before it gets cold.
here is the link to the old postwith pics and video: https://www.thirdgen.org/forums/ca...ro-z-28-a.html (1985 Camaro Z-28 ZZ4 350 5spd 3.73 posi)
Old Oct 22, 2008 | 07:09 PM
dpmalibu's Avatar
Re: 1985 Camaro Z-28 ZZ4 350 5spd posi selling as roller/part out
Make me some offers on whole car,Motor,trans,rear or rolling body. It needs to go.
Old Oct 24, 2008 | 06:35 PM
dpmalibu's Avatar
Here are some new prices:
For the whole car minus just the motor I want $3000 firm.
All you have to do is drop in your motor. I don't think you can beat that for a clean body, with a good trans, newer exhaust, lowered suspension , aftermarket rear suspension parts, rebuilt rear (all new parts including Auburn pro posi, ring and pinion , Moser axles and stud girdle cover), 16" wheels in exc. condition,clean interior (new carpet, headliner , 4th Gen seats, nice stereo).
Price can be lower if you don't want certain parts.
If you want just the rear i will pull it. If you want it it the way it sits I want $900. Minus the stud girdle cover $800 or minus the axles and stud girdle cover $ 600.
Rear suspension parts :
Spohn adjustable LCA's $160
Spohn adjustable Pan hard bar $100
UMI bolt on Relocation brackets $65
I may sell the headers/ Mufflex Y -pipe and the cat back if I happen to sell the body w/o these items.
same thing with the aluminum radiator and electric fan.
Old Oct 25, 2008 | 09:20 AM
TransAm_85's Avatar
Car: 1985 Trans Am
Engine: built 355
Transmission: th350
Axle/Gears: Borg warner 3.08's
how much do you want for the headers and y-pipe
Old Oct 25, 2008 | 10:58 AM
dpmalibu's Avatar
$250 plus shipping for headers and Y-pipe. The Y-pipe would bve very awkward piece to ship though .
Old Oct 26, 2008 | 12:56 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
will you take number 4 on your list, 400 . i don't need the trans. thanks,bryan
shoot me a pm.
Old Oct 27, 2008 | 03:09 PM
dpmalibu's Avatar
pm sent.
Old Nov 4, 2008 | 02:45 PM
dpmalibu's Avatar
no longer trying to sell as a roller. Must buy as a turn key car or trade.
Frozer!!!
Jan 19, 2024 04:55 PM
MantyZ28
16
Dec 21, 2015 11:02 AM
Reddeath210
Oct 6, 2015 08:20 AM
mcgarnicle
Aug 12, 2015 04:58 PM
SiCkRs
Aug 8, 2015 08:12 AM
