383 Stroker Parts
383 Stroker Parts
Selling the parts to make an excellent S/S 383 Pump gas short block. Built a 408 instead. These parts should be good for a 500HP set-up plus a little juice. Here's what I've got:
1) 3.75 Eagle ESP Cast crank(New, but had it turned 10/10 to clean-up the journals.) internally Balanced. 2-pc seal.
2. 5.85" Pro-Power 4340 Forged H-beam rods (New). These are stout.
3. JE/SRP Forged Pistons +.030 (Used but in excellent shape). One of the eight was damaged and I bought a new one. P/N146997. Step dish design. 16CC dish. 9.6-9.8 to 1 Compression with 64CC heads.
4. This rotating assembly gives you a deck ht. of 9.010". You can use a std. deck block (9.025") or just cut the deck .010-.015" for zero deck.
5. I also have a Std. bore 4-bolt single main seal block. You will need an adapter to fit this crank into the block but this block uses std. lifters for a hyd. roller cam. This saves $$$$ on cam kit.
You will need bearings and rings. I may ahve a set of rings but they will add to the cost. Will sell the rotating assembly seperate from the block.
Rotating Assembly--- $500 w/Block $600.
Block alone--- $150
I have a couple of cams as well. Both Hyd. and Hyd Roller. If your interested. These are new. $100/ea
Block alone--- $150
Car: 86 firebird
Engine: 385 dart pro 1 heads 13 to 1
Transmission: th350 4800 stall
Axle/Gears: 33 spline nine inch
Re: 383 Stroker Parts
would you consider seperating the pistons and rods from the rest and if so how much can you send pics of the pistons to ssgtgaines@sbcglobal.net
where are u located
where are u located
Last edited by ssgtgaines; Oct 31, 2008 at 08:07 PM. Reason: Automerged Doublepost
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Hey, I need that crank. Hopefully you can seperate? Is it a 400 Crank, or a 383 crank? Thanks!
Mike, I've got 2 hyd.roller cams. One is a Crane#119821, 276/284Dur, 112LSA, .480/.509". I'll get the specs on the other later today.
Bradley, I'll seperate the crank for $130. You pay shipping.
Thanks,
Thanks,
Im interested. Please send me some pics. Is this a direct swap into a regular 350 block? (I know about clearancing, etc. etc...) What I mean is, would my blocks bearing journals have to be modified? Let me know please
Bradley23150@yahoo.com
Mike,
No this is a retro-fit cam. However, my other cam is a step-nose cam. If I remember correctly it's a single pattern 239@.050. But I don't rememeber the LSA or lift. I'll get the specs shortly.
Bradley,
The crank,rods and pistons are ready to go into a 2pc seal 350+.030 block. Yes there wil be some clearancing involved but this is normal for a 383 deal. You will have a problem with using this crank with 5.7" rods. Needs longer rods to allow piston to crank counterweight clearance.
Kelly
Kelly
I don't think it matters...retrofit or not... as long as I use the right cam button. I believe any cam for Gen 1 or LTx is fine provided the grind matches my needs.
Bradley,
Kelly
Kelly
Nonetheless, How much shipped to 33635, and can I get some pics? Thanks!
Email: Bradley23150@yahoo.com
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Just a heads up....Those PM rod bolts will probably need a little grinding for clearance to accomodate the longer stroke. The clearance is needed for the cam...unless you use a small base circle cam.
Does this mean I need .010 Oversized Main, and Rod Bearings with this crank?
Can I PLEASE get some pics and a price to zip 33635, Email: Bradley23150@yahoo.com
thx
thx
These H-beam rods shouldn't need much clearancing for the cam. Depends on lift, lsa, etc. I've used these with a Hyd. roller 289/294, .560" lift w/o any clearancing. But a small base circle will certainly clear.
Bradley, I'll send lics. Have been very busy and haven't been to my shop in a couple of days.
Thanks,
Thanks,
Thanks,
Thanks,
But, How can I use 5.7 rods with this crank? What makes it so different from any other 383 crank?
Thanks.
Transmission: 200R4
Pictured are your PM rods. Make a note of how the rod bolt holds the cap together. The head of the bolt will probably need a little clearancing to clear the cam. Also pictured is a rod that will not need clearancing. See how the bolt mounts from the bottom up....just the opposite of yours? Photos are small but you get the idea.
Oh okay, thanks for the info. Although I dont really see a difference? Nevertheless. Ide like pics and PRICE of the crank shipped to 33635.
Thanks!
Thanks!
Transmission: 200R4
Yeah...sorry. If the pictures were larger, you'd see the difference right away. It's simple. Your PM rod has the bolt head on top and a nut on the bottom. The other rod has the bolt head on the cap and there is no nut. The bolt threads right into the body of the rod. Where your bolt head is on the PM rod is exactly what needs clearancing.
Oh okay. I thought the block just got clearanced to solve that problem...
Either way, can I get a price shipped to 33635?
Thanks.
Thanks.
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
How much just for the crank shipped to 08872?
LT1Formula
20
Nov 14, 2015 12:02 AM
mhatfield 14
Oct 24, 2015 07:48 AM
