Engine Electrical and Misc. Engine Bay Parts
Old Nov 27, 2008 | 08:51 PM
sr20fd3st's Avatar
Car: 84 Z28, 68K Miles
Engine: 10.5 Compression 350
Axle/Gears: 3.83
The following are from an 84 Camaro Z28 with 60,000 Miles. Everything is Subject to Best Offers
Map Sensor - $35 shipped (Located on Driver Side Firewall on Bracket with A/C Relay)
A/C Relay - $12 shipped(Located next to Map Sensor)
A/C Accumulator (Drier) - $20 Shipped (have little bracket for it too)
If you buy one of the first two things and want the bracket, it's yours.
If there is anything else you need as far as engine sensors/electronics/whatever I'll try and see if it's something I don't need. I havn't pulled it all out of the engine bay yet, only the above stuff.
Will takes pics per request.
-Oliver
Old Nov 29, 2008 | 10:33 PM
TTz31's Avatar
Car: 89 Iroc-Z28
Engine: 454 BBC
Transmission: TH400
Axle/Gears: 10 bolt 2:73 Posi
Re: Engine Electrical and Misc. Engine Bay Parts
Do you happen to have the engine wiring harness from the junction on the driverside firewall. It can be cut, I basically need the plug and about a foot of all the wires. pm me
Old Dec 3, 2008 | 07:38 PM
sr20fd3st's Avatar
Axle/Gears: 3.83
pm/d you
Also pulled this sucker from the car.
A/C Condenser. $50 plus shipping. Looks to be in fine shape. I'll always go with whoever ships it for cheapest. ups, fedex, usps. Sometimes one is cheaper than the other and other way around.
Also selling the Rochester Q-Jet Carburetor and the Aluminum Intake Manifold.
Carburetor is a electric choke Q-jet with 17086046 ID on it, and under it it says, 1846 JPJ. Will sell it for whatever it's worth, I'd guess like around $150 OBO?
Am Selling the distributor also, will pull it tonight and post pics of both carb and distributor
Attached Thumbnails Engine Electrical and Misc. Engine Bay Parts-mini-p1020252.jpg
Old Dec 4, 2008 | 09:11 PM
sr20fd3st's Avatar
Axle/Gears: 3.83
eventually will have evaporator out of car also. will sell that for $50 bucks +shipping OBO.
everything I list is pretty much OBO, as long as within reason.
Will sell this carb $175 shipped
Attached Thumbnails Engine Electrical and Misc. Engine Bay Parts-mini-p1020258.jpg   Engine Electrical and Misc. Engine Bay Parts-mini-p1020256.jpg   Engine Electrical and Misc. Engine Bay Parts-mini-p1020254.jpg
Old Dec 5, 2008 | 10:08 PM
sr20fd3st's Avatar
Axle/Gears: 3.83
Pulled the distributor and took apart just to clean and take pics. Black plastic coil cover is off just to show wiring is okay and coil isnt melted or anything. Worked just fine on the car as far as I could tell, points don't look very worn. Engine has 30,000 miles.
$60 Shipped.
Attached Thumbnails Engine Electrical and Misc. Engine Bay Parts-mini-p1020260.jpg   Engine Electrical and Misc. Engine Bay Parts-mini-p1020262.jpg   Engine Electrical and Misc. Engine Bay Parts-mini-p1020263.jpg
Old May 21, 2009 | 09:59 PM
phazer480's Avatar
Car: '92 Camaro RS 25th Ann.
Transmission: auto
Axle/Gears: stock
would this condenser fit in a 92 v6 3.1 camaro?
Old May 24, 2009 | 12:54 PM
sr20fd3st's Avatar
Axle/Gears: 3.83
Sorry, not for sale any longer. Actually, this whole thread is no longer for sale lol. As for cross referencing condensers (for future reference), just call local gm parts and see if their part numbers for your model and anyother model match. They probably due, since the size and mounting locations probably match any 3rd gen car
Reddeath210
Oct 6, 2015 08:20 AM
86IROC112
Aug 17, 2015 02:00 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
1nastygta
Aug 8, 2015 07:38 PM
