tpi set up n more
Old Dec 13, 2008 | 08:17 PM
jfsiutza's Avatar
Car: 1986 Z-28 al unser silver bullet
Engine: 305 carbed
Axle/Gears: 3.08
tpi set up n more
came off a 1986 Z-28 Camaro LB9... harness is in decent condition..
mice or something got intothe engine chewed away some of the distributor n egr wires I fixed the sections and ran the engine which ran fine for 2months 150OBO +shipping
i also got:
a TBI unit from a 1989 LO3 Iroc-Z with computer and harness...
the harness is a hack...(nightmare!!!) 50OBO+shipping
t-tops (smaller ones from the rumored custom hard-top to t-top conversion)(gimme an offer)
either a T5 (idk if its a WC or not) or a 700R4..which ever gets more $$ offer are in working condition.
the automatic is im my 86Z-28 right now shifts great n fine
I got the pedals and used flywheel n clutch(slave cylinder popped out n lost)..
if u want anyone of the set ups gimme an offer.. ive seen the t5 set up as high as 500..
will consider trades too THANKS justin
located at Zuni NM 87327
Old Dec 14, 2008 | 12:36 AM
87cmroiroc305ho's Avatar
Car: 1987 chevy camaro iroc-z28 305 h.o.
Engine: 305 high output
Re: tpi set up n more
what would you want for the tpi setup, all the bolts, bracket, parts, thermo housing, injectors? how bout that and the Dist. ill pay whatever for + shipping, so what do you want for just the tpi, and just the dist
i have a carb setup if you want to trade
its edelbrock performer edurashine, its clean too
and a holley single plane intake
and my custom bored space plate, 12 point bolts, new gaskets, new bolts, and the wrench for the bolts
the only thing is i need everything to change it.
Old Dec 14, 2008 | 01:00 AM
jfsiutza's Avatar
Engine: 305 carbed
Axle/Gears: 3.08
yes its got all the bolts except for the torx bolts to mount the whole unit to the (heads)engine.. i reused the bolts to mount my proformer intake.. and as i recall one of the plenum bolts were replaced with a regular 12 point bolt
i threw away the plenum gaskets and left everything else on there.. injectors and i also got the plastic aircleaner duct but i dont know how much it would cost to ship an akward item like that
ill price it at 150 OBO.. n u pay for shipping is that kool???
postal zip code is 87327
and for the trade.. i would consider but ive already got a new carb set up on mine n dnt need another sorry.. open to other trades like headders valve covers etc...
Old Dec 14, 2008 | 01:07 AM
jfsiutza's Avatar
Engine: 305 carbed
Axle/Gears: 3.08
oh the distributor i can put back together its gnna need a new cap coil and rotor.. i got the module.. but theres a piece missing i cant remember the name but its a small cylinder type thing that connects to the module.. but i couldnt use the bottom end of the distibutor with the carb set up so i dont know if you would want the distributor since right now its just the base with the wires to the computer coming out of it.. ..
Old Dec 15, 2008 | 04:47 PM
jfsiutza's Avatar
Engine: 305 carbed
Axle/Gears: 3.08
bump..
still got the parts will be cleaning the tpi unit ..
Old Dec 21, 2008 | 10:28 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
any upper plenums?
Vintageracer
Jan 10, 2020 05:33 PM
Grant2k
Jul 10, 2018 04:01 PM
Fast355
Dec 2, 2016 06:33 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
