TPI Painless Wire Harness
Want a title? Post!
Car: 1937 Ford Coupe
Engine: TPI Inside
Axle/Gears: Ford 8" 3.00
I have a used Painless wiring harness for an 86-88 MAF TPI with AT. Has smog pump and canistor connectors and either large cap distributor and adaptor for small cap distributor. It's used and needs a little doctoring up, but still pretty nice. 125.00.
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
Re: TPI Painless Wire Harness
why couldnt this be for an 85...
geez.
i need one of these too
how much are they new?
geez.
Want a title? Post!
Engine: TPI Inside
You made me go and look! 415.00 new from jegs. I took this harness off a Jag that had an 88 TPI 350.
Want a title? Post!
Engine: TPI Inside
Price is firm. I don't know if it is an actual "Painless Wire" harness, but what else could it be? It's not perfect, you will need to fix a couple of wires, maybe even ditch the smog pump wires. If you know your way around a TPI harness you won't have a problem and even if you know nothing about a TPI harness you will still be able to make this work. Thanks for looking.
Sanjay
Aug 12, 2015 03:41 PM
