lots of stuff
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Re: lots of stuff
I need something very specific; it is ALL (as in each piece, brackets, etc) of the hardware used for bolting up the 91-92 front spoiler lip to the car. This means both the top to the bumper and the bottom to the engine pan. Thanks, Nitro
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
Re: lots of stuff
I live in North West Arkansas
- Aluminum Be Cool Radiator $450 almost new
- New Red Headliner (Has slight oil Stain that i will clean out)
- Set of T-tops
-Very mild 383 stroker tbi.
-2.73 Drum Rear End
-Also Headers(not sure which one) ,Y - pipe , 3in. Pipe , to V-force muffler . Sounds really good.
-Brand new fuel pump less than a month old
Tons of other stuff just ask.
The stuff i dont have a price on just offer and if its reasonable it can work.
- Set of T-tops
-2.73 Drum Rear End
Last edited by tyler92; Feb 17, 2009 at 05:55 PM. Reason: More stuff to add or something was sold
Car: 1988 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: WC-T5
Axle/Gears: 2.73:1 Open
Re: lots of stuff
Interested in the TBI wiring harness, as long as it hasn't been cut or modified as well as EGR valve.
pm sent
pm sent
Car: 89 Iroc-Z28
Engine: 454 BBC
Transmission: TH400
Axle/Gears: 10 bolt 2:73 Posi
Re: lots of stuff
You don't by any chance have a c100 connector do you? I don't need the whole harness just a pigtail with about 6 -12" of wire on it.
Re: lots of stuff
Do you the evaporator lower box/housing? I think it also covers the blower motor and bottom of the evap in 1piece, then the top its a seperate piece that removes from the firewall. I really need the bottom, but I'd take both. Let me know
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
Re: lots of stuff
Yeah i sure do Jaice.
We had nasty weather all weekend . I'm sorry if i am keeping anybody waiting.
Thanks a lot
- Tyler
Thanks a lot
- Tyler
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
Re: lots of stuff
Pictures of the T-Tops
The previous owner put rtv on one of the tops to help with leaks
It will come off very easy.
Car: 1992 Camaro RS
Engine: 350 Carb'd
Transmission: 5 Speed
Re: lots of stuff
What color is the car?
I need the plastic piece that clips onto the bottom of the passenger door, its apart of the GFX I guess. All I need is the plastic piece tho for the bottom of the door... And how much would you like for it shipped to 48220 $40-45?
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
Re: lots of stuff
Alright guys im going to be pulling the motor this weekend so I can start getting everything together to start shipping. Thanks
