Complete clutch assembly and flywheel 2pc rms
Old Feb 8, 2009 | 06:12 PM
Bo1226's Avatar
Car: 83 Z28 modified 350
I have a complete clutch assembly just removed from a 305 in very good condition. Clutch was only used for about 6 mos before 305 was pulled to replace w/350 and WC T5. I just sold the 305 and took the complete clutch assembly minus the pilot bearing off. Motor was a 2pc RMS. Let me know if interested. Also have the T5 NWC for sale.
Old Feb 12, 2009 | 09:00 PM
lightwolf's Avatar
Car: 88, RS
Engine: 383 Stroker
Axle/Gears: Stock Peg Leg
Re: Complete clutch assembly and flywheel 2pc rms
How much for clutch? do u have pressure plate too?
Old Feb 12, 2009 | 10:00 PM
Bo1226's Avatar
Yes have clutch and pressure plate. I'll take $40 plus shipping...if interested let me know.
Bo
Old Mar 1, 2009 | 11:21 AM
lightwolf's Avatar
Car: 88, RS
Engine: 383 Stroker
Sorry about the wait i'll understand if you dont have it.
I'm still interested in the clutch/pressure plate. Does the clutch have 14 spline and is it 10.5" dia. I am swaping out a v6 with a v8 so i need to make sure it is going to work.
Old Mar 1, 2009 | 09:19 PM
Bo1226's Avatar
Yes still have it and it is off an 86 z28 w/stock 305. This is the right cluthch for V8 third gen camaro w/T5.
Old Mar 2, 2009 | 11:14 AM
lightwolf's Avatar
Car: 88, RS
Engine: 383 Stroker
The trans is for a v-6 I belive the v-8 was different. How many spline is it?
Old Mar 2, 2009 | 04:26 PM
Bo1226's Avatar
If I understand you right you are saying you are swapping FROM a V6 TO a V8 if this is correct you also have to swap to a V8 Trans. You CANNOT use a V6 trans w/V8 motor...as you have said different splines. Regardless.....the clutch I have is for a V8 T5 going to a V8 305. If you are using any other pieces these will not work for you.
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
KO1
Aug 31, 2015 06:31 PM
