disc brake setup for Moser 9"
Old Feb 12, 2009 | 12:52 PM
bygblok's Avatar
I have both calipers(1le/corvette type), rearend and caliper brackets and a brand new set of cross-drilled and slotted rotors(11 3/4"). The calipers(are used) haven't been used in quite some time so not sure of the condition. They HAVE been ground to clear my 15" billet specialties street lites and the rotors have been drilled for my larger 1/2 wheel studs. I've got around $150 in the rotors alone. Would like to see around that plus shipping for everything from Pensacola Florida. I'll try to have some pics up tonight when I get home. I went with all aerospace brakes on all four corners and this is now in my way.
Old Feb 12, 2009 | 05:48 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
Re: disc brake setup for Moser 9"
pics, im interested...
Old Feb 12, 2009 | 06:27 PM
bygblok's Avatar
I've only got one side off as of right this minute but here's a few pics to get the idea of what I have......
Old Feb 18, 2009 | 08:04 PM
bygblok's Avatar
any interest, I want this stuff to go away. It's a direct bolt-on for a Moser 9" and can use a factory type or 1/2 stud.
Old Feb 18, 2009 | 09:11 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
this won't bolt to my GM 12 bolt truck rear, will it? If you don't know can you measure the bolt pattern and I'll check for myself?
Old Feb 18, 2009 | 09:15 PM
bygblok's Avatar
the brakes could "probably" be made to bolt up(anything can be built I guess) but the rotors are for a 5x4 3/4 " bolt circle and your truck would be a 5x5 so the studs wouldn't fit unless you drilled the rotors. It'd be more work than it would be worth for you to be honest but thanks for looking!!
Old Feb 18, 2009 | 09:50 PM
I have 5 x 4 3/4 axles in it. its waiting to go in my camaro
Old Feb 19, 2009 | 06:57 AM
bygblok's Avatar
still couldn't guarantee a fit for you as the brackets I have are strictly made for the big bearing 9" housing ends. These calipers DID come from a camaro or corvette(can't remember which for sure) and use a corvette/camaro style rotor(11 3/4" diameter) They bolted on my 9" perfectly but I just decided while it was apart to go ahead with the aerospace brakes on all four corners. I still have the left side bolted to the car. As soon as I get some time I'll try to get pics assembled as well so everyone can get the idea of how this goes together. Thanks again, Bill
Old Feb 24, 2009 | 12:24 AM
camaro1j's Avatar
Car: 92 Camaro
Engine: 406 sbc
Axle/Gears: 9" ME with 4.56 gears
I am interested. Do the calipers have emergency brakes? I have a t56 trans and would need them.
Old Feb 24, 2009 | 10:25 AM
bygblok's Avatar
yes, they have the brackets and levers for the e-brake still on them. You'd have to get cables etc. but that shouldn't be hard to find from maybe a 4th gen f-body,
Old Feb 24, 2009 | 07:00 PM
camaro1j's Avatar
Car: 92 Camaro
Engine: 406 sbc
I will give you $150.00 shipped.
Old Feb 24, 2009 | 07:11 PM
bygblok's Avatar
check your PM's.
Old Feb 24, 2009 | 11:11 PM
bygblok's Avatar
sale pending........
Old Mar 2, 2009 | 08:38 PM
bygblok's Avatar
sold!! Thanks James and TGO!
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
