[MO] Torsen diff
Old Mar 7, 2009 | 03:32 PM
84TA400's Avatar
Want a title? Post!
Car: 04 SS Silverado.. 84 T/A
Engine: ZZ4
Transmission: 700R4 B&M holeshot
Axle/Gears: Dana 44 3.92
Torsen diff
almost new take off Zexel Torsen differential. Bought from SLP. $100 fits 7 5/8 GM rear ends.
Old Mar 8, 2009 | 10:46 PM
vortecblazer's Avatar
Re: Torsen diff
100+shipping or 100shipped?
Old Mar 9, 2009 | 02:01 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
Re: Torsen diff
ttt
100 shipped or + shipping
Old Mar 10, 2009 | 01:04 PM
Re: Torsen diff
forgot to ask is it a 2 or 3 series?
if it's 3 and you take paypal than i'll take it for $100shipped
Old Mar 11, 2009 | 10:27 PM
kzhurley's Avatar
Car: 86 IROC-Z
Engine: 406
Transmission: TH400
Axle/Gears: Ferd 9 inch/ 4.11 spool
Re: Torsen diff
pm sent...
Old Mar 18, 2009 | 08:43 PM
Re: Torsen diff
you still have the diff?
Old Mar 19, 2009 | 09:17 AM
RockJay81's Avatar
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
Re: Torsen diff
is this a posi diff
Old Mar 19, 2009 | 07:05 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Torsen diff
Originally Posted by RockJay81
is this a posi diff
Yes.
JamesC
Old Mar 21, 2009 | 03:33 PM
christian'sZ's Avatar
Re: Torsen diff
Originally Posted by RED_DRAGON_85
I'm sorry but that is a perfect example of a stupid question.
If it was a posi unit it would be labeled as a posi unit. Instead it's labeled as a torsen diff, which leads me to believe it's a torsen diff.
That might have been a bit too harsh
Sorry
well mr wizard what exactly is a torsen diff & how dose it work.
Old Mar 21, 2009 | 10:39 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
Re: Torsen diff
since i assume that the firestorm is aimed at me, i will say that i am not exactly sure of the precise way it works, only that it is a purely mechanical form of limited slip that actually has no clutches or preload (in early models) and is instead a torque biasing device.
if the driveshaft can supply say 100 lb-ft and one tire can only hold 20 lb-ft, then the other wheel gets a multiplification factor of that (iirc, its like 500, but i cant be sure, dont quote me)
the main benifit is that you will never have a situation where you are transitioning on or off the limited slip
the bad news is that if you are off roading and one wheel is in the air, the other wheel gets exactly zero torque, since zero times infinity is still zero.
oh, and i am not a homo.
sorry for the confusion though.
Old Mar 21, 2009 | 10:44 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
Re: Torsen diff
Originally Posted by rockjay81
...blah blah blah, i dont know much about diffs so blah blah blah...
i dont know much about diffs either but
http://en.wikipedia.org/wiki/Torsen
wikipedia has an article on everything
its amazing what you can learn if you take the time to do the reading.
i got flamed plenty when i first started asking questions about cars, but with a bit of common sense and the desire to learn stuff, you can be nearly an expert on anything
Old Mar 22, 2009 | 03:57 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: Torsen diff
Is the dif sold?
Old Mar 24, 2009 | 10:04 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Re: Torsen diff
Still available? I am local as well.
Old Mar 25, 2009 | 07:19 AM
JamesC's Avatar
Re: Torsen diff
Hey, Gladstone,
I am/was interested in a 3.73 rear that the OP was selling. He never got back to that thread, so either he doesn't check often or he's playing.
JamesC
Old Mar 25, 2009 | 06:55 PM
Re: Torsen diff
diff is sold, i know because it's in my garage right now. send him a PM he will respond. good guy and fast shipping
Old Mar 25, 2009 | 08:49 PM
JamesC's Avatar
Re: Torsen diff
Good to know.
JamesC
Old Mar 25, 2009 | 09:14 PM
heff17's Avatar
Car: 89 Camaro
Engine: 383 w/ 450HP
Transmission: TKO-600
Re: Torsen diff
I know a guy around me that is wanting to sell this same torsen diff for $150. He said it has 5k miles.
Numbah-1
Oct 2, 2015 08:27 AM
Vincent135
Sep 28, 2015 10:50 PM
