[IL] Full set of autometer ultralite gauges, speedo,tach, etc etc, and 15 gallon fuel cell
Autometer ultralites
3 3/8ths mechanical speedometer, 4700 miles
3 3/8ths indash tach
2 1/16ths mechanical oil pressure gauge
2 1/16ths mechanical water temp gauge
2 1/16ths electrical fuel level gauge {short sweep} 0-90 ohms
2 1/16ths electrical volt meter {short sweep}
all gauges are MINT,work flawlessly, and include everything,besides the original boxing.
will not seperate, only want to sell as a group ordeal.
also have a 15 gallon rci aluminum fuel cell{with foam} and 0-90 ohm sender...
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
Re: Full set of autometer ultralite gauges, speedo,tach, etc etc, and 15 gallon fuel
prices?
Car: '88 IROC-Z medium orange metallic
no idea on the dimensions, check out summits website.
its a natural finish aluminum fuel cell,15 gallon with 0-90 ohm sender, gimme a few minutes and ill post pics.
Car: 1987 Camaro Iroc-Z
Engine: small block chevy stroked
Can you split the gauges up??? All i need is the oil pressure gauge set up.If so let me know how much shipped to 45344 and payment through paypal.
Car: 1988 RS Camaro
Engine: Undetermined
Transmission: TH400
Axle/Gears: Stock
are you interested in a trade for the gauges? I have some forged pistons for sale.
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
What kind of roller cam set-up are you looking for? I have a brand new Comp Cams Custom ground hydraulic roller cam (.544 I .556 E 230 I 236E 114 lope separation). This is a custom grind I had made based off of the XFI 280. I'm interested in only the gauges.
thats a little more cam then i was looking for to be honest, i have a SD tpi car, didnt wanna spend days tuning it...
Transmission: 200R4
Yeah, I understand. I do have a low mileage Comp 264HR-12. Here are the specs.
http://www.compcams.com/Cam_Specs/Ca...?csid=212&sb=2
Since it's used, I'll throw in a low mileage set of GMMC 5.7 full roller rockers.
Both cam and rockers were in the same motor with 7000 miles. The motor was a rocket when pulled.
Transmission: 200R4
Sorry, I was fading last night. That's GMPP. GM Performance Parts. They are the factory performance Bow-Tie roller rockers. Both items are still in an assembled motor. If you still have the gauges on Friday, I will dissassemble for some pictures. Give me an e-mail address to send them to.
Car: 94 blazer, 1985 berlinetta
Engine: 4.3, 5.7
Axle/Gears: 3.73 and soon to be 3.73 posi
where are you located? are the gauges set up to be installed in dash? I have a custom aluminum gauge plate those sizes should fit in. I have a berlinetta and need to get rid of the digital dash assy as the turn signals and such dont work. Im converting everything over to mechanical. would you take 300 shipped to 08062 by any chance?
Engine: 4.3, 5.7
and also, what do you use for turn signal indicators when running a setup like that?
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
got a pic of the FP gauge? also what's the range on it and is the electric fpr sender included?
thx
edit: sorry, ignore my post.. i just noticed it said fuel LEVEL
thx
Engine: 4.3, 5.7
I will buy as a package
Ghettobird52
Jul 5, 2024 11:18 PM
colton_carlson
Mar 8, 2019 12:21 PM
